- Thank you received: 5334
PlasmaC Voltage Divider
1 year 3 months ago #332374
Replied by PCW on topic PlasmaC Voltage Divider
Much better.
1 year 2 months ago - 1 year 2 months ago #332672
by zzrzzr
Replied by zzrzzr on topic PlasmaC Voltage Divider
Thanks.
I soldered both resistors in the + und - Line inside the plasma source and also connected the 2 torch-start pins of the plasma-source with the Spindle enable + and Spindle enable - -Pin of the Mesa 7i76e-board.
When I power up the plasmacutter it instantly fires although the torch is not activated in plasmac. When I remove the 2 wires from spindle enable +- then the plasmacutter doesn't start when powered up.
When I measure between s-en+ and e-en- with a multimeter there is no connection but the plasma fires when started. Maybe somebody has an idea ? Do I need an additional relays ? With the hypertherm powermax 1000 G3 on the same mesa-card this didn't happen ?
Maybe sb has an Idea?
Last edit: 1 year 2 months ago by zzrzzr.
1 year 2 months ago #332677
Sounds like you may have the spindle ENA polarity backwards.
1 year 2 months ago #332688
by zzrzzr
I tried it again without changing anything and the plasmacutter started without firing at startup. Then I loaded the materal and tried to make a cut through 10mm mild steel. The torch fired, but the machine didn't move. And the torch went on and of a few times.
Why does that happen ? And why doesn't the machine move ?
- snowgoer540
- Thank you received: 907
1 year 2 months ago #332692
by snowgoer540
Replied by snowgoer540 on topic PlasmaC Voltage Divider
Sounds like it did not get an Arc OK signal.
The criteria is different depending what Mode you are using:
linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#plasma:modes
1 year 2 months ago - 1 year 2 months ago #332710
by zzrzzr
I use mode 0.
I connected the divided arc voltage to the thcad and now the machine moves when it cuts, but it also goes on and of very often. You can see it here:
Could it also be a grounding-problem as the part is very small and I attached the ground clamp to the aluminium box where a steel grid is inside.
And why does it dive down in the middle of the part ? It seems to stop when the float switch is activated.
Time to create page: 0.307 seconds
