Using M201 and Python to Lookup a CSV Table File and Using It's Values
4 years 2 months ago #249692 by my1987toyota
Slight update of the code now P, i, and s output the true Float, Integer, and String when Linuxcnc is loaded through
Terminal
the readable text version
#remap version 12.02 import emccanon import sys import interpreter import csv             # These Global Variables are mainly intended for M201 but can be used elsewhere             # these codes can be changed to meet your machines need feeds1 = 'F150'    # feed value for Z to pick up part vacOn = 'M7'    # M_code for turning on vaccum pTime = 'G4 P0.5'   # G_code for pause time to allow vaccum to stabilize def M201(self, **words):     print(words)     P = words['p']       # outputs a Float value     i = int(words['p'])  # Converts Float value to integer     s = str(i)           # Converts integer to string     feedersFile = open('feeder_V1.04.csv')     coordinatesReader = csv.reader(feedersFile)     locationData = list(coordinatesReader)     fdrPos = locationData     if P < 0:         print("error, a P parameter must be passed")     if P > 0:         print('P = ' , float(P))    # open linuxcnc in terminal to read the float output of 'P'         print('i = ', int(i))       # open linuxcnc in terminal to read the integer output of 'i'         print('s = ', (s))          # open linuxcnc in terminal to read the string output of 's'         print('Going to Feeder' + ' ' + s)         self.execute('G53 G0' + ' ' + fdrPos[i][1] + ' ' + fdrPos[i][2] + ' ' + 'Z0.0 C0.0')         self.execute('G53 G1' + ' ' + fdrPos [i][3] + ' ' + feeds1)         self.execute(vacOn)         self.execute(pTime)         self.execute('G53 G1 Z0.0 C0.0' + ' ' + feeds1)         self.execute('M161 P' + s)     return interpreter.INTERP_OK
the python file
File Name: remap_12.02.py
File Size:1.5 KB
The following user(s) said Thank You: tjtr33, tommylight
Time to create page: 0.149 seconds
