QtPyVCP Tutorial
6 years 5 months ago #166548 by helmholtz
Replied by helmholtz on topic QtPyVCP Tutorial
I'm having a hard time getting the CSS file to be applied when following the tutorial. Any changes I make to the 'style.qss' file are ignored. In fact it seems like the current Mint system theme is applied to the VCP instead. anything that I can try to force the CSS? thanks!
6 years 5 months ago #166627 by KCJ
Replied by KCJ on topic QtPyVCP Tutorial
Do you have the correct QSS file specified in the YAML file?
If so it will override any system theme.
application: kwargs: # Specify the application wide stylesheet. stylesheet: {{ file.dir }}/ui/style.qss
6 years 5 months ago #166633 by helmholtz
yes, that is exactly what is in the YAML file. If I change the version number or name in the YAML file those changes show up, so I know I'm editing the correct file.
I also tried it editing the .INI file, but that also seem to be ignored.
[DISPLAY] # Path to QSS style sheet file STYLESHEET = 'path to .QSS file'
lastly, I tried 'pip install kwargs' thinking that I had a problem with python as I've already found I was missing other dependencies while setting up both QtPyVCP and the tutorial. This didn't make any difference. QT designer seems like really intuitive software but this is my first Python project so I'm concerned I'm just missing something more fundamental that's creating difficulties in following what should be a pretty basic tutorial.
for reference I'm using this ISO, though I don't know think that is relevant:
forum.linuxcnc.org/9-installing-linuxcnc...aver-mint-iso#165631
6 years 5 months ago #167071 by helmholtz
It doesn't matter which VCP is chosen, but in all cases the same lines are logged in terminal: 'custom stylesheet disabled'
$ linuxcnc LINUXCNC - 2.8.0~pre1 Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.qtpyvcp' Machine configuration file is 'xyz.ini' Starting LinuxCNC... Unrecognized line skipped: ;Tool Pocket X Offset Y Offset Z Offset Diameter Remark Found file(REL): ./hallib/core_sim_3.hal Note: Using POSIX realtime Found file(REL): ./hallib/spindle_sim.hal Found file(REL): ./hallib/simulated_home.hal qt5ct: using qt5ct plugin qt5ct: using qt5ct plugin QFileSystemWatcher::addPath: path is empty qt5ct: custom style sheet is disabled
6 years 5 months ago #167151 by KCJ
I guess I am not entirely sure what the problem you are having is. Is the QSS not being applied? If so make sure there are no syntax errors in your style sheet, as that will prevent it from loading, but it should throw errors indicating the problem.
You can try using the --stylesheet option when launching QtPyVCP and passing the full path to the QSS file and see if that works. Run qtpyvcp -h for help on how to use the option.
The qt5ct plugin warnings you are seeing are completely unrelated to QtPyVCP. This is the Qt System settings plugin, used for setting global fonts, icon sets etc. I don't know why it prints those messages, but they are talking about the QTPyVCP style sheet.
Cheers,
Kurt
6 years 5 months ago #167152 by helmholtz
To clarify, the QSS files are being ignored when the VCP loads. It does not matter what VCP is chosen. I have not edited any of the files. In all cases the Mint system theme overrides any and all style settings within the VCP. I've attached a screenshot of one of the sample vcp files.
again, I've not edited or changed anything. I hope this makes sense.
Moderators: KCJ, Lcvette
Time to create page: 0.139 seconds
