- Thank you received: 25
Back to the Problem that is not solved for years ! ( that's what it looks like )
SetUp : Mill
x-axis : 410 mmy-axis : 520 mmz-axis : 110 mm
home at : x0 y520 z110 ( left back top )
SetUp : ATC-Spindel
put air-pressure : drop_tool;
release air-pressure : pull_tool;
SetUp : Tool-Changer
Horizontal rack along x-axis at y520 with n-positions;
SetUp : Tool-Length-Sensor :
Tool-change Position at x385 y380 z110;
Trigger at x385 y380 z41.4145;
For the tool-change with PB I have 4 CASE plus some subCASE for each :
CASE_1.) change tool in auto-mode with G-Code in program : T5 M6 G43
CASE_2.) change tool in mdi-mode with G_Code in command-line : T5 M6 G43
CASE_3.) change tool by insert new tool-number (5) in PB and press button( M6 G43)
CASE_4.) change tool by hand at G30 ( and do, or do not touch-off )
So where do I get started image missing /media/kunena/emoticons/cool.png
