Probe Basic and Carousel ATC with Geneva and Stepper
1 year 6 months ago - 1 year 6 months ago #327457 by IB_CnC
Probe basic was prepared to control a dumb motor FWD and REV just by two outputs.
I didn't know so I bought a stepper motor with gearbox and driver because at first I wasn't considering the geneva wheel.
Started out with the MESA stepgen but later on I thought might as well keep that for a future rotary axis, as the small PCB is 10 bucks + 2x a relay, so thats why I set it up like this.
Last edit: 1 year 6 months ago by IB_CnC.
1 year 6 months ago #327460 by tommylight
OK, thank you both.
If so, using a stepgen (if possible without joint/axis) and setting the scaling and steps/unit with the FWD/REW outputs from carousel to stepgen should work in hal...
The following user(s) said Thank You: IB_CnC
1 year 6 months ago - 1 year 6 months ago #327476 by IB_CnC
For now I'll just accept the situation and carry on with the small delay, until I got the whole toolchange process sorted.
Im at the point now where the carousel extends, gets detected, spindle moves to clearance height, spindle unclamps the tool etc..
All 5 sensors are working, Carousel Home, Carousel Index, Carousel IN position, Carousel OUT position and the Spindle Tool Clamped and Tool Released sensors.
Now its time to program the final movements, placing and removing a tool from a pocket.
Will be a little different probably compared to other carousel toolchangers where the carousel moving in and out takes the tool from the spindle.
When no tool is loaded it has to move down, clamp the tool, moving to the right to take a tool from the pocket, carousel retract, spindle up again and resume.
Or with a loaded tool it has to move in front of the carousel, moving to the left into the pocket, unclamp, up, rotate to new tool, down again etc.
Should be fun, hopefully it won't get fooked. :-D
1 year 5 months ago - 1 year 5 months ago #327570 by IB_CnC
Made the first toolchanges today!
Altough, taking a tool from the ATC is not yet working optimally.
I was customizing the M21 and M22 subroutines to get it working, but in the end found ''toolchange.ngc' which is also playing a part.
I probably need to add some movements specific to my atc to toolchange.ngc instead of to the M22 subroutine. :-)
Other than that pretty happy it's doing its job!
Last edit: 1 year 5 months ago by IB_CnC.
The following user(s) said Thank You: tommylight, Clive S, pommen
1 year 5 months ago - 1 year 5 months ago #327633 by IB_CnC
Today I rewired the carousel stepper driver to the MESA hardware stepgen nr4, which was a 5min job.
Consecutively, I spent 4 hours trying to get it running again.
The stepgen in velocity mode is controlled mainly by "velocity-cmd" which takes a float value.
Positive for CW and negative for CCW.
Main problem was setting the float value with the two digital outputs ( motion.digital-out-03 & motion.digital-out-04) that are triggered for CW and CCW carousel rotation.
But in the end I solved it using MUX4: linuxcnc.org/docs/2.4/html/man/man9/mux4.9.html
# --- (Carousel CCW / REV)
net ATC_Motor_CCW mux4.0.sel0 <= motion.digital-out-03
net ATC_Motor_CW mux4.0.sel1 <= motion.digital-out-04
net ATC_Motor_DIR_VEL hm2_7i96s.0.stepgen.04.velocity-cmd mux4.0.out
net ATC_Motor_CCW_SPD mux4.0.in1
sets ATC_Motor_CCW_SPD 5000
net ATC_Motor_CW_SPD mux4.0.in2
sets ATC_Motor_CW_SPD -5000
net ATC_Motor_OFF_SPD mux4.0.in0
sets ATC_Motor_OFF_SPD 0
net ATC_Motor_OFF2_SPD mux4.0.in3
sets ATC_Motor_OFF2_SPD 0
#*******************# ATC Stepgen#*******************
# Step Gen signals/setup
setp hm2_7i96s.0.stepgen.04.steplen 20000       # Step length (nanoseconds) 20 usec
setp hm2_7i96s.0.stepgen.04.stepspace 20000  # Step space (nanoseconds) 20 usec
setp hm2_7i96s.0.stepgen.04.maxaccel 50000    # Maximum acceleration (steps/second^2) so 1/10 second to full speed
setp hm2_7i96s.0.stepgen.04.maxvel 5000         # Maximum velocity (steps/second)
setp hm2_7i96s.0.stepgen.04.step_type 0           # Regular step type
setp hm2_7i96s.0.stepgen.04.dirsetup 50000      # Direction setup time (nanoseconds) 50 usec
setp hm2_7i96s.0.stepgen.04.dirhold 50000        # Direction hold time (nanoseconds) 00 usec
setp hm2_7i96s.0.stepgen.04.control-type 1        # Control type (1 for velocity control)
setp hm2_7i96s.0.stepgen.04.enable True            # Enable the step generator initially
No more delayed response!!!
The following user(s) said Thank You: tommylight, Lcvette
1 year 5 months ago - 1 year 5 months ago #327648 by IB_CnC
Updated vid image missing /media/kunena/emoticons/smile.png
I was also planning to mount the toolsetter on the ATC, so it becomes available when the carousel is out of the way.
But I'm a little worried it will trigger due to the movement of the cylinder, as the end cushioning is not that good, need to solve that first.
Moderators: KCJ, Lcvette
Time to create page: 0.064 seconds
