Killing a little time waiting on Christmas Eve festivities to commence over here on the east coast of the US. So Merry Christmas to anyone reading this!
Figured I'd take a minute and give an update... Adding the user view is officially in the pipeline, I definitely see value in it, and I think others will as well. Phill had a good idea for double clicking the button to change it to SET, so I incorporated that and it seems to work well. Also, I made it so upon clicking SET, it records the view, and then immediately applies it so the user can tell right away if it stuck or not.
A few comments from things I learned/saw during the process:
1. I wonder if anything can be done to make applying the view more stable? I am willing to do what I can to help here, if you can give me some nudges in the right direction as far as where to look, and how it's working/what the current programmatic issues are?
2. If you had the grid showing, and if you are in a P view, and change to the User View, the grid will not be displayed. However, I noticed that if you go to Z view first, then click User view, the grid will be shown. The current work around I've implemented is to switch to Z, then switch to User View, it seems to be unnoticeable, but wanted to report back on it in case it can be fixed at the source.
3. Along the lines with #2, but not having to do with User View, if you have a grid applied, when you click P, the grid will disappear. I've tried Axis, and this mimics axis functionality, but the thing that makes me question if it is correct is that if I do the following, the grid will be shown in a P view:
a. click P
b. set the user view to that view
c. apply the user view (which in QtPlasmaC's case, sets Z first, then applies the user view)
d. the grid will be shown in a P view
Anyhow, again, willing to help however I can, but some of this is probably over my head.
Thanks, and I hope everyone enjoys the holidays!
