What's the best way to override the facing.py utility?
  • itsgudenuf
  • Topic Author
  • New Member
  • New Member
2 years 6 months ago #298029 by itsgudenuf
I'm using qtdragon_hd RIP and I'd like to override the facing.py utility found in linuxcnc-dev/lib/python/qtvcp/lib/gcode_utility/ so the utility will only perform climb milling when doing a facing operation.
Of course, I'd like to keep things "upgrade safe" so that's why I'm not just dropping in my on facing.py in the source tree.
Thank!
2 years 6 months ago #298032 by cmorley
# put/rename the file in YOUR CONFIGFOLDER/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py import sys import importlib from qtvcp.lib.qt_ngcgui.ngcgui import NgcGui from qtvcp.lib.auto_height.auto_height import Auto_Measure from qtvcp.core import Path, Action PATH = Path() ACTION = Action() # get reference to original handler file so we can subclass it sys.path.insert(0, PATH.SCREENDIR) module = "{}.{}_handler".format(PATH.BASEPATH,PATH.BASEPATH) mod = importlib.import_module(module, PATH.SCREENDIR) sys.path.remove(PATH.SCREENDIR) HandlerClass = mod.HandlerClass # return our subclassed handler object def get_handlers(halcomp, widgets, paths):     return [UserHandlerClass(halcomp, widgets, paths)] class UserHandlerClass(HandlerClass):     print('\nCustom subclassed handler for custom facing utility - loaded\n')     def init_utils(self):         from qtvcp.lib.gcode_utility.facing import Facing          # <<<< modify this         self.facing = Facing()         self.w.layout_facing.addWidget(self.facing)         from qtvcp.lib.gcode_utility.hole_circle import Hole_Circle         self.hole_circle = Hole_Circle()         self.w.layout_hole_circle.addWidget(self.hole_circle)         try:             from qtvcp.lib.gcode_utility.hole_enlarge import Hole_Enlarge             self.hole_enlarge = Hole_Enlarge()             ACTION.ADD_WIDGET_TO_TAB(self.w.tabWidget_utilities,self.hole_enlarge, 'Hole Enlarge')         except Exception as e:             print("Utility hole enlarge unavailable: {}".format(e))         #LOG.info("Using NGCGUI utility")         self.ngcgui = NgcGui()         self.w.layout_ngcgui.addWidget(self.ngcgui)         self.ngcgui.warp_info_frame(self.w.ngcGuiLeftLayout)         self.auto_measure = Auto_Measure(self.w)         self.w.layout_workpiece.addWidget(self.auto_measure)         self.auto_measure._hal_init()
Try this.
save it here on your system:  CONFIGFOLDER/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py
Then change the one line I marked to load your new facing program.
from qtvcp.lib.gcode_utility.facing2 import Facing
I assume it's basically the same. Make sure it's in the path stated above and change the import line/program to suit the name.
Is your version suitable for integration into linuxcnc?
Chris
  • itsgudenuf
  • Topic Author
  • New Member
  • New Member
2 years 6 months ago #298039 by itsgudenuf
Thanks Chris.
I'll give this a try as soon as I get back into town.
Yes, I hope my version will be suitable for integration. Once it's adequately tested I'll be sure to share it for integration.
~Brian
  • itsgudenuf
  • Topic Author
  • New Member
  • New Member
2 years 6 months ago #298617 by itsgudenuf
It took a little of extra time to get things working like I wanted.  I've now got a side to side climb only facing routine, along with an always climb milling path moving inward.
I modified your suggested qtdragon_hd_handler.py to work with other customizations you've suggested in other posts.  I don't like how I hard coded the path to the face.py file but it works for now.
If you think the additional facing routines could be helpful to others, I'll make a PR on Github.
For anyone who might want to try this with an RIP installation, here's what needs to happen:
  • copy the new images to linuxcnc-dev/share/qtvcp/images/gcode_utility/
  • mkdir <CONFIGDIR>/qtvcp/lib/gcode_utility/  and copy face.py and face.ui
  • adjust qtdragon_hd_handler.py as appropriate
Time to create page: 0.130 seconds
