Problem with user defined MCode
08 Nov 2012 03:15 #26351
by REEEN
Problem with user defined MCode was created by REEEN
Hello,
I use user defined Mcodes (M101 and M102) to activate my pallet changer.
M101 is side 1 and M102 is side 2
This Mcodes wait for a pin to be true so I used the wait for script to manage the queue buster thing.
The Mcode script sets a start signal true and waits for another Pin to be true via wait for script and then the Mcode script sets the start signal back to false.
The Code works fine but sometimes the M101 or M102 Signals are not set to false and the Pallet changer does not work.
This only happens when I use it in a Gcode programme. It never happens when I use this mcodes as mdi command.
Can anyone explain why this happens and what I can do against that?
I think there's something with the M30 command. ...
Thank you very much!
Greets Rene
Greets Rene
08 Nov 2012 08:32 #26355
Can you be more specific about this "wait for script"? Where did you find it?
Perhaps you can attach the M101 and M102 files to the reply message?
Replied by andypugh on topic Problem with user defined MCode
08 Nov 2012 18:02 #26365
by Rick G
Replied by Rick G on topic Problem with user defined MCode
You may also want to attach a example of the G code that causes the problem.
Rick G
Rick G
08 Nov 2012 20:19 #26368
by BigJohnT
Replied by BigJohnT on topic Problem with user defined MCode
Why don't you use Classicladder to run your pallet changer?
09 Nov 2012 02:26 - 09 Nov 2012 02:27 #26389
by REEEN
Replied by REEEN on topic Problem with user defined MCode
I come from Germany I'm a mechatronics trainee my exames are next week so I'm very busy this week, so I have no acces to my machine Iam going to post the Files and everything else on saturday.
I created a comp file to control my Pallet changer ( I don't mean the toolchanger).
Hal Pins are not accesible through Gcode so I defined this Mcodes to set the start signal and I used this wait for script to to set the start Signal back to false after turning the Pallet changer.
If this Signal is not set to false the switch in the comp file won't switch back to case 1 it will wait forever for the start pin to be set false first.
If I wouldn't wait for the Pin to be set true my Pallet changer would turn again and again and again...
This works for most of the time within Gcodes and it always works as Mdi command !
I'll gonna show you the files
Some Information on my machine I have a Chiron Fz16 with a Table turning Pallet Changer like this one:
Chiron Fz16 running with Linuxcnc
The machine in the video is exactly the same. You can also see the Pallet changer in action in this video. It works with various sensors and pneumatic actors.
I'm going to post my Pallet changer component too.
But the variables and pins have german names and comments.
Thank you !
Greets REEEN
Thank you !
Greets REEEN
Last edit: 09 Nov 2012 02:27 by REEEN.
09 Nov 2012 07:19 #26392
by BigJohnT
I think I understand now what your doing... I do hope you do well on your exams next week.
11 Nov 2012 09:44 #26446
www.linuxcnc.org/docs/html/gcode/m-code....ec:M66-Input-Control
It would be nice to be able to use something like #<hal.motion.spindle-speed-out> in the G-code though.
I have half a feeling that it has been done at least experimentally.
A way round this is to link the pins to analog or digital G-code inputs.IHal Pins are not accesible through Gcode
11 Nov 2012 17:36 #26451
by REEEN
It has been done read chapter 18-20:
link
link
Time to create page: 0.179 seconds
