CNCCustoms wrote: When I did some scratching, I discovered that at first homing of the machine (Index homing enabled) , a pin called encoder.nn.position-latched is written with the axis current encoder position. The homing begins as usual, switch is tripped, then the index-enable goes on and then off and then the machine moves the axis to the axis encoder position of encoder.nn.position-latched position.
