- Configuring LinuxCNC
- Advanced Configuration
- XXYZ vs. XYYZ Changes - No Motion after Hal and INI Changes
- BobBobberton
02 Mar 2019 06:44 - 02 Mar 2019 17:55 #127479
by BobBobberton
XXYZ vs. XYYZ Changes - No Motion after Hal and INI Changes was created by BobBobberton
Hoping to get some help with an issue I'm having. I built a CNC with dual Gantry Axis and Single axis for Z and Y(?)
When I built the machine I thought that I had my XYZ Configuration correct....
Long Story Short I have a nice working machine that Homes and does not miss steps.
The problem is I set it up Dual X Axis motors (Forward/Revers) that travel the Gantry. and Y Axis that goes Left to Right.
Z Axis Up/Down.
This config is causing me headaches in Fusion 360 as the X and Y are opposite.
I've tried Post Processor Edits (Flipping X and Y) but this caused Radius issues...
I then thought I would just Re-Work my HAL and INI file to Change from XXYZ to XYYZ Config... Simple right?
I edited my Joints and cannot find anything wrong in my setup. With my XXYZ setup homing and everything works but as soon as I change my HAL and INI to my XYYZ edit Nothing Works....
No homing or Jogging on any axis. Nothing moves....
Any ideas? No Errors on start up. And When Homing it shows Z try to move in Program but No Movement....
INI and HAL Files Posted Lower with Pic of Machine for Reference.
Z Axis Up/Down.
Last edit: 02 Mar 2019 17:55 by BobBobberton. Reason: Mistake
- Thank you received: 7063
02 Mar 2019 13:52 #127498
Replied by tommylight on topic XXYZ vs. XYYZ Changes - No Motion after Hal and INI Changes
Double post !
The first attachment is empty.
- pl7i92
- Thank you received: 358
02 Mar 2019 14:04 #127504
by pl7i92
Replied by pl7i92 on topic XXYZ vs. XYYZ Changes - No Motion after Hal and INI Changes
why at all changing the INI
only the HAL needs to be chasnged in pinout
02 Mar 2019 14:07 #127505
Ini has to be changed !
- BobBobberton
02 Mar 2019 17:08 - 03 Mar 2019 23:55 #127519
by BobBobberton
Replied by BobBobberton on topic XXYZ vs. XYYZ Changes - No Motion after Hal and INI Changes
I'm sorry about the double Post. I didn't think it posted. New to the Forum. It was waiting for Moderator. My Bad.
Thanks for the Reply's. Some how the files I attached were empty. Linux to Windows Issues I guess...
Anyway here are the HAL and INI files Before and After Trying to change from XXYZ to XYYZ.
I am just copying the text into the files to make the change and then it does not move. I can Paste the old files back in and it works normal.
In order of XXYZ.hal Working, XXYZ.INI Working, XYYZ.hal Non Working, XYYZ.IN Non Working
Thanks for your time and help.
XXYZ.Hal Working System
XXYZ.INI Working System
XYYZ.HAL No Motion Not WorkingXYYZ.INI Non Working NO Motion
# Generated by stepconf 1.1 at Sun Jun 22 11:16:29 2008
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
# ---had to add a fourth zero to the line below for the fourth joint
loadrt stepgen step_type=0,0,0,0
loadrt pwmgen output_type=1
# Base Thread
addf pwmgen.make-pulses base-thread
# Servo Thread
addf stepgen.update-freq servo-thread
# Spindle
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 100.0
setp pwmgen.0.scale 10000
setp pwmgen.0.offset 0
setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
# Outputs to Motors
setp parport.0.pin-01-out-invert 1
net spindle-pwm => parport.0.pin-01-out
net x1step => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-03-out-invert 1
net x1dir => parport.0.pin-03-out
net x2step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
setp parport.0.pin-09-out-invert 1
net x2dir => parport.0.pin-09-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
setp parport.0.pin-07-out-invert 1
net zdir => parport.0.pin-07-out
net estop-ext <= parport.0.pin-10-in
net yenable => parport.0.pin-14-out
net spindle-on => parport.0.pin-17-out
# Estop Input
# Spindle IO
# Home/Limit Signals
net max-home-z <= parport.0.pin-11-in-not
net min-home-y <= parport.0.pin-12-in-not
net max-home-x1 <= parport.0.pin-15-in-not
net max-home-x2 <= parport.0.pin-13-in-not
# net both-home-x1 joint.0.home-sw-in <= parport.0.pin-11-in-not
# net both-home-x2 joint.1.home-sw-in <= parport.0.pin-12-in-not
# net both-home-y joint.2.home-sw-in <= parport.0.pin-13-in-not
# net both-home-z joint.3.home-sw-in <= parport.0.pin-15-in-not
# Axis X / Joints 0 and 1
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net x1pos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net x1pos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net x1step <= stepgen.0.step
net x1dir <= stepgen.0.dir
net x1enable joint.0.amp-enable-out => stepgen.0.enable
net max-home-x1 => joint.0.home-sw-in
net max-home-x1 => joint.0.neg-lim-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net x2pos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net x2pos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net x2step <= stepgen.1.step
net x2dir <= stepgen.1.dir
net x2enable joint.1.amp-enable-out => stepgen.1.enable
net max-home-x2 => joint.1.home-sw-in
net max-home-x2 => joint.1.neg-lim-sw-in
# Axis Y / Joint 2
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net ypos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net ypos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net ystep <= stepgen.2.step
net ydir <= stepgen.2.dir
net yenable joint.2.amp-enable-out => stepgen.2.enable
net min-home-y => joint.2.home-sw-in
net min-home-y => joint.2.neg-lim-sw-in
# Axis Z / Joint 3
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 35000
setp stepgen.3.dirsetup 35000
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net zpos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net zpos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net zstep <= stepgen.3.step
net zdir <= stepgen.3.dir
net zenable joint.3.amp-enable-out => stepgen.3.enable
net max-home-z => joint.3.home-sw-in
net max-home-z => joint.3.pos-lim-sw-in
# ---E-Stop---
net estop-ext => iocontrol.0.emc-enable-in
# net estop-out => iocontrol.0.emc-enable-in
# ---Manual tool change---
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
[EMC]
MACHINE = 3x4CNCRouter
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 2.0
MIN_SPINDLE_OVERRIDE = 0.0
MAX_SPINDLE_OVERRIDE = 2.0
DEFAULT_LINEAR_VELOCITY = 0.20
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 10.0
INTRO_TIME = 5
PROGRAM_PREFIX = /home/me/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
PYVCP = custompanel.xml
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XXYZ kinstype=BOTH
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 31250
SERVO_PERIOD = 1000000
[HAL]
HALFILE = 3x4CNCRouter.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = XXYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.100
DEFAULT_LINEAR_VELOCITY = 2.0
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_X]
MAX_VELOCITY = 1.8
MAX_ACCELERATION = 3.6
MIN_LIMIT = -0.01
MAX_LIMIT = 32.5
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 32.5
MAX_VELOCITY = 1.8
STEPGEN_MAXACCEL = 4.0
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = -0.25
HOME_LATCH_VEL = 0.02
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 2
# HOME_SEARCH_VEL = 0
# HOME_LATCH_VEL = 0
# HOME_USE_INDEX = NO
# HOME_SEQUENCE = 0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 32.5
MAX_VELOCITY = 1.8
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
# HOME_SEQUENCE = 0
# Axis Y
[AXIS_Y]
MAX_VELOCITY = 1.8
MIN_LIMIT = -0.01
MAX_LIMIT = 45.5
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 45.5
MAX_VELOCITY = 1.8
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = -1.5
HOME_LATCH_VEL = 0.015625
HOME_SEQUENCE = 3
# HOME_SEQUENCE = 0
# Axis Z
[AXIS_Z]
MAX_VELOCITY = 1.8
MIN_LIMIT = -9.0
MAX_LIMIT = 0.01
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -9.0
MAX_LIMIT = 0.01
MAX_VELOCITY = 1.8
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = 0.1
HOME_SEARCH_VEL = 0.2
HOME_LATCH_VEL = -0.015625
HOME_SEQUENCE = 1
# HOME_SEQUENCE = 0
# Base Thread
# Servo Thread
# Spindle
# Outputs to Motors
net y1step => parport.0.pin-02-out
net y1dir => parport.0.pin-03-out
net y2step => parport.0.pin-08-out
net y2dir => parport.0.pin-09-out
net xstep => parport.0.pin-04-out
net xdir => parport.0.pin-05-out
# Estop Input
# Spindle IO
net min-home-x <= parport.0.pin-12-in-not
net max-home-y1 <= parport.0.pin-15-in-not
net max-home-y2 <= parport.0.pin-13-in-not
# net both-home-y1 joint.0.home-sw-in <= parport.0.pin-11-in-not
# net both-home-y2 joint.1.home-sw-in <= parport.0.pin-12-in-not
# net both-home-x joint.2.home-sw-in <= parport.0.pin-13-in-not
# Axis X / Joint 0
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net min-home-x => joint.0.home-sw-in
net min-home-x => joint.0.neg-lim-sw-in
# Axis Y / Joints 1 and 2
net y1pos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net y1pos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net y1step <= stepgen.1.step
net y1dir <= stepgen.1.dir
net y1enable joint.1.amp-enable-out => stepgen.1.enable
net max-home-y1 => joint.1.home-sw-in
net max-home-y1 => joint.1.neg-lim-sw-in
net y2pos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net y2pos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net y2step <= stepgen.2.step
net y2dir <= stepgen.2.dir
net y2enable joint.2.amp-enable-out => stepgen.2.enable
net max-home-y2 => joint.2.home-sw-in
net max-home-y2 => joint.2.neg-lim-sw-in
# Axis Z / Joint 3
# ---E-Stop---
[EMC]
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 31250
[HAL]
[TRAJ]
COORDINATES = XYYZ
LINEAR_UNITS = inch
CYCLE_TIME = 0.100
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
# Axis X
[AXIS_X]
MAX_VELOCITY = 1.8
MIN_LIMIT = -0.01
MAX_LIMIT = 45.5
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 45.5
MAX_VELOCITY = 1.8
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = -1.5
HOME_SEQUENCE = 3
# HOME_SEQUENCE = 0
# Axis Y
[AXIS_Y]
MAX_VELOCITY = 1.8
MIN_LIMIT = -0.01
MAX_LIMIT = 32.5
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 32.5
MAX_VELOCITY = 1.8
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
# HOME_SEQUENCE = 0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 32.5
MAX_VELOCITY = 1.8
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = 0.0
HOME_SEQUENCE = 2
# HOME_SEQUENCE = 0
# Axis Z
[AXIS_Z]
MAX_VELOCITY = 1.8
MIN_LIMIT = -9.0
MAX_LIMIT = 0.01
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -9.0
MAX_LIMIT = 0.01
MAX_VELOCITY = 1.8
SCALE = 10180
FERROR = 0.1
MIN_FERROR = 0.05
HOME_OFFSET = 0.1
HOME_SEQUENCE = 1
# HOME_SEQUENCE = 0
Last edit: 03 Mar 2019 23:55 by andypugh. Reason: Added Code Tags
- BobBobberton
02 Mar 2019 17:19 #127521
by BobBobberton
I got this files posted now on this board. Thanks
I will post a pic of machine for reference.
- BobBobberton
02 Mar 2019 17:20 #127523
by BobBobberton
- BobBobberton
02 Mar 2019 18:09 #127526
by BobBobberton
Replied by BobBobberton on topic XXYZ vs. XYYZ Changes - No Motion after Hal and INI Changes - SOLVED!!!!
I found my problem finally.... I missed my enable output. Yenable was not recognized after changing to Y1 and Y2.
Changed to xenable and all was well in the World.
See below
*ORIGINAL*
*******net yenable => parport.0.pin-14-out
*WRONG*
*CORRECTED*
******net xenable => parport.0.pin-14-out
See below
*ORIGINAL*
*WRONG*
*CORRECTED*
The following user(s) said Thank You: andypugh
Time to create page: 0.117 seconds
