Spindle Step/Dir servo ramp down before stop on M stop command.
5 years 6 months ago - 5 years 6 months ago #205319 by andypugh
NoJo wrote: I added the permanent spindle enable -
setp [HMOT](CARD0).7i76.0.0.output-15 1
That works - the spindle remains enabled ( it is in fact how I want it finally - I have a manual handwheel to loosen and tighten the 5C collet, and the spindle servo is supposed to hold the spindle fixed against my hand tightening/loosening force - it does too!)
How that will work with the C_Axis mode remains to be battled with..
Actually, that's pretty good news. It will make the C axis easier too.
I would suggest
net machine-is-on [HMOT](CARD0).7i76.0.0.output-15
. That will enable the drive and lock the spindle when the machine is on (F2 button on many GUIs) . And you can press F2 if you do need to move a spindle or an axis by hand.
At the end, the spindle still does not ramp down and I am digging, but not obvious!
I think this is probably the stepgen enable going false imediately.
You have
net spindle-enable => [HMOT](CARD0).stepgen.02.enable
which would normally be right, but in this case I would suggest trying
net machine-is-on => [HMOT](CARD0).stepgen.02.enable
instead.
There is still the issue that e-stop will set machine-is-on to false, and stop the spindle dead. But then that might be what you want.
Last edit: 5 years 6 months ago by andypugh.
The following user(s) said Thank You: timo
5 years 6 months ago #205326 by NoJo
THAT is a resounding Success!
Thank you Andy. Works perfectly. E-stop does stop all dead, but that is what I would want - Sort of what the 'E' is in E-stop!
This works very well indeed.
I fear I am still in need of much more assistance on this machine!
Still to get going is :
  • C_Axis with proper orient control.
  • Be able to jog the C_Axis with a jog wheel.
  • ATC - much later as the ATC still has to be designed, but for that I would like to have some details of how it will be driven by 'HAL' - read many posts on ATC's, esp EMCO machines, but still know too little.
  • Basic live tool - a single mill spindle fixed in radial or axial plane - also much later as the spindle is in progress.
  • To prioritise I think the C_Axis and its jog is first.
    I very much need guidance on the C_Axis - It is a lot more complex and the few posts I have read that seem very much to be what I wish to achieve are very detailed and created by chaps who really know this stuff well!
    Where do I start?
    It is really nice to watch this lathe do its thing now. The servos are dead quiet, the spindle motor likewise, a 5C collet system so not even any wind noise from the chuck jaws - just sits there and quietly gets on - and then comes to a halt gently!
    Thanks Andy
    5 years 6 months ago - 5 years 6 months ago #205360 by andypugh
    Late reply as I have been investigating an idea.
    I liked the idea of configuring the C-axis as a locking-indexer then using the "joint.2.unlock" pin to control whether the spindle was under velocity control or C-axis control.
    But it seems that you can't jog an indexer, and can only do G0 moves.
    Both these restrictions seem arbitrary, I might look in to removing them.
    But, back to your machine:
    It's easy enough to set up a PID controller to add a a second velocity command to the spindle stepgen command for positioning.
    What complicates this is that you might have 1,000,000 full revolutions already on the spindle when you engage the C axis, and the PID would want to unwind (very nearly) all of them to go to +90 degrees, for example.
    Does your spindle encoder work? (It is in the HAL file, I see. Does the HAL pin spindle.0.revs increase by 1 for every spindle rotation?
    (You can test this with the HAL meter, under the "Machine" menu in the Axis GUI.)
    Here is a possible solution.
    1) Define a user M-code to enable C-axis control.
    2) Set up a 4th PID to control the C axis
    3) Add the output of that PID to the spindle velocity command.
    4) When enabling the C-axis PID, also set the "index-enable" for the spindle encoder. This means that there will be a largely uncontrolled movement of up to 1 turn when the C-axis is engaged, but then it will be referenced to the encoder index.
    First you need to make the lathe into a 3-axis machine.
    I suggest making a copy of the entire current working config (just copy the ~/linuxcnc/configs/CNC_lathe folder and rename the new one)
    In the INI in the [DISPLAY] section:
    GEOMETRY=XZC
    In the [KINS] section
    JOINTS = 3 KINEMATICS = trivkins coordinates=XZC
    [TRAJ] COORDINATES = XZ
    [AXIS_C] MAX_VELOCITY = 40.0 MAX_ACCELERATION = 100 MIN_LIMIT = -3600 MAX_LIMIT = 3600 [JOINT_2] TYPE = ANGULAR HOME = 0 FERROR = 1.0 MIN_FERROR = .1 MAX_VELOCITY = 40.0 MAX_ACCELERATION = 350.0 P = 2 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 0.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 MIN_LIMIT = -3600 MAX_LIMIT = 3600 HOME_OFFSET = 0.000000 HOME_SEARCH_VEL =0 HOME_LATCH_VEL = 0
    And see if a C-axis appears in the GUI. (with only these changes it will f-error immediately if you try to move it)
    Then attach the HAL and INI from that config here so that we can have a look at setting up the C-axis.
    5 years 6 months ago - 5 years 6 months ago #205361 by PCW
    Note that hostmot2 in master supports clearing the stepgen position
    and also supports index on the stepgen
    Last edit: 5 years 6 months ago by PCW.
    5 years 6 months ago #205370 by andypugh
    PCW wrote: Note that hostmot2 in master supports clearing the stepgen position
    I think that we will probably end up ignoring stepgen counts and position, but time will tell.
    5 years 6 months ago #205372 by PCW
    You can do that (using encoder feedback only) but it may compromise
    the servo response somewhat.
    Time to create page: 0.230 seconds
