NoJo wrote: This becomes tricky, or at least as I understand it. Would simply re-homing not clear the C_Axis DRO to zero?
If so , that would lose the historical position of the C axis when re-entering C_Axis mode - would that matter?
How do I set this up?[/quote]Firstly, the machine would probably need to be configured to start up in C-axis mode, and with the C-axis as part of the homing sequence.
RBC wrote: Is it possible to use any programming statements in these M101 files.
andypugh wrote:
This might actually be possible...
The C axis should then be configured in the INI with HOME_USE_INDEX = 1 , HOME_SEARCH_VELOCITY = 0 and HOME_LATCH_VELOCITY = 100 (or some suitable number)
Then connect joint.2.index-enable to the encoder index-enable
Not sure how to do this - where/what is 'encoder index-enable' ?
Remove the "setp index-enable" line from the M100 script. Instead use:Code:halcmd setp halui.joint.2.unhome 1 sleep 1 halcmd setp halui.joint.2.unhome 0 halcmd setp joint.2.home 1 sleep 1 halcmd setp joint.2.home 0
RBC wrote: I need to poll for stepgen velocity=0 before executing position-reset so I dont get the following errors.
Is this something I can do?
