(Solved) Index signal for Orient, G33.1, M19 with proximity sensor
23 Dec 2021 14:31 - 31 Dec 2021 22:46 #229809 by anton610
Hello,
I'm trying to get rigid tapping to work.
My setup consists of a servo motor with encoder and a spindle. The trasmission is approx 1:1,64 with an GT 5 belt.
I want to get the index signal from an proximity sensor mounted on the spindle.
I followed talla's tutorials, but I failed on the input from the sensor in my hal file.
File Name: microVMC.hal
File Size:16 KB
Does someone have experience in this sort of indexing an spindle?
Many thanks!
Best Regards Anton
Last edit: 31 Dec 2021 22:46 by anton610.
24 Dec 2021 00:22 #229840 by andypugh
It's relatively simple in principle, you just need to connect the encoder counter A and B to the servo encoder A and B, but connect the encoder index to the prox sensor rather than the index in the encoder.
And you need to get the encoder scale right."approx" 1:1.64 isn't good enough, you should use the exact ratio.
24 Dec 2021 03:23 #229854 by Henk
It seems that you are using a mesa card. What exactly are you not getting right? The config part or the actual wiring?
Are you using a 24v DC proxy ? PnP or NPN.?
If 24v, you need to be carefull because the encoder inputs on the mesa card can only handle 7v max I think so you need a level shifter between the proxy and the mesa card. A simple optocoupler IC should be fast enough, surely faster than the proxy.
24 Dec 2021 07:37 - 24 Dec 2021 07:40 #229863 by anton610
Hello,
Many thanks for the quick reply!
I'm using a PNP NC sensor in 24v.
I've tried to connect the sensor to the mesa encoder input with a level shifter/stepdown to 5v (4,08). Then the encoder index was always on.
I'm using the Differential signals input of the mesa card, because with the ttl, i get no input from the servo driver.
Do i have to bridge the gnd of the encoder input to the indx - of the encoder?
Thanks!
Best regards and merry christmas Anton
Last edit: 24 Dec 2021 07:40 by anton610.
24 Dec 2021 08:06 #229866 by Henk
There are jumpers to select differential/single for each of A B and Z encoder inputs. Try selecting single with the z jumper only.
What type of level shifting have you used?
24 Dec 2021 08:15 #229867 by Henk
24 Dec 2021 09:15 #229869 by anton610
Hello Henk,
I'l try to set the z input to single.
I used a voltage divider with two resistances. So the voltage is going from 24 to 5v(4,08v).
Could it be a problem whrn the signal is to long. Because the a and b signals are short and the index is longer.
Br anton
24 Dec 2021 09:55 #229870 by Henk
I don't think the length matters.
Can you verify the signal with a multimeter? If you can, switch back to differential and connect the 0v to the Z/ pin.
But make sure you don't apply more than 7v to the mesa encoder pins.
Also check that the signal goes low enough when connected, also try to reach 5 v when high. There is a certain hysteresis so low must be lower than a certain value
24 Dec 2021 10:59 #229871 by anton610
Hello Henk,
With a multimeter i got 4,08v when the sensor is triggerd and 0v when not closed.
I think a have to solder a new divider which reaches 5v
Br anton
24 Dec 2021 15:06 #229893 by PCW
As Henk says, you need to jumper the index input for single ended mode.
Also 4.08V is fine for a high level because when the encoder inputs are set
for single ended mode, the input threshold is 1.65V.
