- Thank you received: 23
But i would prefer the solution by Mazak. They used iirc a custom tool change command and added the desired spindle angle.
It looked something like this: T01XX while XX equals the desired spindle orientation.
I would be super thankfull for some help, cause this is really a critical feature. I guess the same problem is not just drilling but also milling pockets at an angle other then 0° or 90°.
The machine can hydraulically lock the spindle via hirth coupling in 12 positions. This is of course quite importent for tuning tools and broaching tools.
I stumpeled across this pdf. Its from a Doosan Mill but it has the same construction as the Mazak and a PP is already there in Fusion.
