Retrofitting an 89 Chiron FZ12W aka Igor
5 years 2 months ago #217245 by anfänger
Since the Machine is running well except for some minor issues:
mesa card sometimes doesn't answer I din't figure out what's the problem after four or five tries ist works well.
and the Encoders sometimes loose signal, then i'ts time to wiggle some cables and the it works again.
I wil do some milling in the next time, so I addressed some other thing which I disliked. The first LED I added was falling apart, so I added e third of the ones I installed later:
[img
I am happy with that. Last winter the water treatment for the Coolant I attached to the mill froze. So It was time to get a new one. This time It's in the room next to my heater room, so it won't freeze again. And I got a mixer which eases refilling a lot. But I have to carry it to the machine. I think for my hobby workshop it is OK.
[img
[img
And I removed the old tool storage and made new ones on Din rails
[img
and I made me some tool tags, the third version I liked best (left one I found on thingiverse, middle my first try, right ma final version)
[img
This wee I should get some magnets, wich should make the even more convenient ti see what tools are loaded. By just sticking the to the housing.
The tool cart also got an upgrade with two short din rails
[img
Hopefully this will keep me more organized, but knowing me I doubt it a bit.
5 years 2 months ago #217491 by anfänger
Finished the tool storage for the mill yesterday:
[img
Hope this will work as good as I think
4 years 5 months ago #244008 by anfänger
Having trouble with the old lady.
After an engraving when she was homing, the z aches started humming and I got an Joint following error.
Did the a full restart, can power her up z is humming, but as soon as I try to move Z the following error kicks in.
My first Ideas was that the brake release is defective, but I checked that. The brake releases just fine and Z is free to move.
I didn't change the PID. I can rule out the encoder (this looks different, then the machine is runnings slowly to an endstop (happens on x some times usually a wiggle on the cable at the drives helps))
With the Z Axis trouble sooting is a bit tricky.
To rule out the Z out / in on the Mesa board I can go to a different analog out and encoder in (X and Y are fine). Which would be my first step now cause it's easy, but I doubt that's the reason though it
Has anyone here a suggestion where to start?
Thanks Patrick
To rule the Mesa board out I could use
4 years 5 months ago #244225 by radom
any update?
I would try swapping axis at simodrive
if you touch Z axis motor with your hand do you feel it vibrating? does it get warm when not moving only holding its weight?
I had to change my Y axis motor because it was getting hot, turns out when opening it, it was rusty inside
My Z axis motor is vibrating, you can't see a movement in DRO in linuxcnc even a micron but you can feel it
4 years 5 months ago #244240 by anfänger
no progress here,
It's not the mesa board, I checked that.
I can see the Encoders jumping, and see the Servo oscillating.
But it won't move more than +-0.05mm
I removed the belt an supported the the Axis so I can play a bit around.
Without the weight of the z axis it doesn't even oscillate.
The encoder works fine, With the drive disabled and the brake released the servo ban be turned easily by hand. I should have a drive for a 4th axis at least its written on the simudrive. I think it's time to search the drive documentation and check if its the servo or the drive. If its the drive and I can use the 4th axis drive a I am fine.
If it's the servo I'll search for a new china servo with drive.
4 years 5 months ago #244325 by andypugh
Maybe the servo has lost a phase? (or the drive has)
You can check the servo with an ohm-meter (with it disconnected from the drive). It could be a loose phase wire somewhere, too.
Time to create page: 1.566 seconds
