Set up using AMC AB15A100 drives, brushed DC motor Prototrak Plus with Encoders
4 years 5 months ago - 4 years 5 months ago #242170 by new2linux
Many thanks, andypugh!!
I will be checking the 2 small transformers for voltage over the weekend.
Many thanks for your time.
Edit: There are 2 transformers, 1 is 5.6 v DC; the other 1 is burnt out, it was 24 v DC, went to TB-2. I plan to try the other 5.6 v DC transformer to both TB-1 & TB-2.
Many thanks, I am very greatful for the help!!
Last edit: 4 years 5 months ago by new2linux. Reason: note about transformers
4 years 5 months ago #242302 by new2linux
Over the weekend, I used the 5.6 v DC transformer (power supply to TB-1) & then, used a 12 v rechargeable battery to supply power to TB-2. The same error message appears both times, "5i25.0.7i77.0.1.analogoutout0-scalemax not found". To be clear, TB-5, pins 1 & 2 are not connected to anything, yet. I have ordered replacement 24v DC transformer.
Many, many thanks for helping, all suggestions are warmly welcomed.
4 years 5 months ago #242431 by andypugh
Without LinuxCNC running, open a terminal.
halrun
loadrt hostmot2
loadrt hm2_pci
show pin
exit
Copy and paste the output here.
4 years 5 months ago #242436 by new2linux
andypugh, Many thanks!! The file is attached/inserted.
File Name: halrunError.txt
File Size:20.17 KB
4 years 5 months ago #242537 by andypugh
It hasn't found the 7i77. The most likely explanation is that field power is not being supplied to the IO board section.
4 years 5 months ago #242542 by new2linux
andypugh, thank you for your help!! A new 24 v DC power supply will arrive this weekend, around the 14th. The A-M-C engineer is traveling early this week.
Many thanks for all the help & suggestions.
Time to create page: 0.358 seconds
