ubergeek wrote: Thank you for the suggested changes. Unfortunately, the changes did not solve the problem. I also moved the wire to pin 6 and changed the step config and the HAL file as mentioned and still nothing.
ubergeek wrote: How would i set the dummy S1000 command?
ubergeek wrote: I guess i don't follow what you mean by adding it to the gcode.
