Forum Header
Error during setup Z to run Blacktooth laser
10 years 11 months ago #66067
by ubergeek
Replied by ubergeek on topic Error during setup Z to run Blacktooth laser
Ok, I have toiled over the HAL settings and everything shows that the Z direction is set up correctly, but the laser will still not fire. I Tried changing the settings in the stepconfig to point to pin 7 on the BOB and moved the wire to match and the system will still not fire. I then change the X direction to pin 6 and moved the wire back to 6 on the BOB and the laser does fire every time the X direction is told to move. This rules out a cable issue but still doesn't explain why the laser will not fire when the gcode tells pic 6 to fire. I also found that if i set the Z direction to reverce the laser will come on at the start of the z code and stay on until i power cycle the whole PC. i am begining to think that something is really long with PC but i do not have another to test this theory.
I also connect a voltage meter to PIN 6 on the BOB and the voltage is not changing when it is all set up correctly.
One last thing that puzzles me is if i press the Z Direction + or - on the main LinuxCNC screen the laser will "blink on" for a brief second and the software red e stop (in the top left corner) along with the power button (next to it) both grey out and i need to reset it before i can use it again. I'm not sure if this is normal or not.
10 years 11 months ago #66096
by cncbasher
Replied by cncbasher on topic Error during setup Z to run Blacktooth laser
rather than run around in circles , post your FULL config as an archive , and also the gcode program your testing with .
what is your interface to the laser , and what type of laser co2 or diode ?
10 years 11 months ago #66100
by ubergeek
The laser is a Blacktooth 40 watt Co2 kit by Build you CNC (
www.buildyourcnc.com/blacktoothlasercutterandengraver.aspx
The test gcode is attached Prizm-02_TEST. As for the config file I am still a noob at this so I may have posted these wrong. Sorry for that, I posted the 2 files from the config folder that I think you are needing. Let me know if this works or doesn't. Thank you for your help.
10 years 11 months ago #66109
Replied by andypugh on topic Error during setup Z to run Blacktooth laser
I think that there is some confusion here between the machine config and the G-code.
The G-code example is clearly using the spindle on / spindle off commands to control the laser and does not contain any Z-moves
It looks like you have configured the machine to use Z axis direction to control the laser.
Your G-code sample will probably work as-expected if you change this:
To
It is relatively easy to make a config that allows both modes of control, if that would be useful.
Personally I think that M62 M63 is more appropriate than either.
net ystep => parport.0.pin-04-out
net ydir => parport.0.pin-05-out
net zdir => parport.0.pin-07-out
To
net laser motion.spindle-on => parport.0.pin-07-out
10 years 11 months ago #66114
by cncbasher
i presume your wanting to rasterize images ? , rather than cutting
if you want to do both , then the best way is to have 2 configurations .
10 years 10 months ago #66538
by ubergeek
Thank you for the suggested changes. Unfortunately, the changes did not solve the problem. I also moved the wire to pin 6 and changed the step config and the HAL file as mentioned and still nothing. I did learn how to modify the HAL file. I know it's easy but you don't know until you try. Any other ideas out there for this? I realize it has to be something i need to change in the HAL file. I just can't find the fix for it.
Thanks in advance for the help.
Time to create page: 0.116 seconds
