Forum Header
Parallel port config? - probably
- Gr8funTargets
- Topic Author
8 years 6 months ago #108362
by Gr8funTargets
Replied by Gr8funTargets on topic Parallel port config? - probably
Morning all
I've copied the file Marvin.stepconf and the folder "Marvin" to the configs folder on the new machine.
Then edited the file Marvin.hal.
I added a # at the start of the line with "loadrt probe_parport"
Saved and tried it.
Still no change.
No movement of the axis, despite them moving on the screen.
I've powered off ALL devices including the BOB, power supply, drivers and PC and restarted them all.
Stil no change.
I was planning on changing the location of the PC so have a longer and new parallel cable, so I've swapped this out too just in case.
No change.
In case it is helpful, here is the Marvin.hal file
My logic is now pointing at the BOB, but I'm no expert here - hence me asking for help
Are there any tests I can perform?
Many thanks for your persistence with this.
ATB
Danny
Saved and tried it.
Still no change.
Stil no change.
No change.
# Generated by stepconf at Sun Jul 13 21:22:44 2014
# overwritten when you run stepconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
#loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
net spindle-on <= motion.spindle-on
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net ydir => parport.0.pin-03-out
net zstep => parport.0.pin-07-out
setp parport.0.pin-07-out-reset 1
setp parport.0.pin-08-out-invert 1
net zdir => parport.0.pin-08-out
net spindle-on => parport.0.pin-09-out
net xdir => parport.0.pin-14-out
net ystep => parport.0.pin-16-out
setp parport.0.pin-16-out-reset 1
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 50000
setp stepgen.0.dirsetup 50000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 50000
setp stepgen.1.dirsetup 50000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 50000
setp stepgen.2.dirsetup 50000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
ATB
Danny
- Thank you received: 1480
8 years 6 months ago #108374
Replied by Todd Zuercher on topic Parallel port config? - probably
Well, the first thing I would check on your BOB; many of them require an external power source(s) such as by a USB cable to the computer. Do you have those connected?
- Gr8funTargets
- Topic Author
8 years 6 months ago #108389
by Gr8funTargets
Hi Todd
Yup, I have power from the driver power supply into the micro USB. This has not changed since it was last working a couple of weeks ago (when the PC died).
It is a ZP5A-INT Breakout board
image missing http://www.windwhistle.co.uk/cnc/driver-BOB.jpg
(This shows what I have, the pic was taken when I was first setting up, hence the lack of wires to the drivers etc )
The is one red LED lit to show it has power.
Interestingly, there are no LEDs lighting when the motors *should* be running, that suggests it is either not getting a signal or not processing it.
8 years 6 months ago #108494
Replied by andypugh on topic Parallel port config? - probably
Start LinuxCNC from the command line (with the command "linuxcnc") and see what output you get.
But if the UI loads and LinuxCNC starts it sounds like the software side of things is correct. So i would start to suspect hardware (including the parallel port hardware).
There are some suggestions here: www.cnczone.com/forums/stepper-motors-dr...driver-problems.html that the enable signals might be problematic. Perhaps the new MB can't quite source enough current to drive the enables?
Does anything else seem to work? Inputs (limit switches) would tell us a lot.
The following user(s) said Thank You: Gr8funTargets
- Gr8funTargets
- Topic Author
8 years 6 months ago #108509
by Gr8funTargets
Thanks Todd and andypugh for all your help - it is very much appreciated.
For completeness of the thread I have now had a multimeter on the pins of the parallel port and with the use of the port tester here..
wiki.linuxcnc.org/cgi-bin/wiki.pl?Parallel_Port_Tester
I could prove the parallel port is working fine.
Having achieved this, I have now ordered a new BOB as that is the next link in the chain.
ATB
Danny
ATB
Danny
8 years 4 weeks ago #118439
by luka_339
Replied by luka_339 on topic Parallel port config? - probably
So does this mean that GA-E3800N motherboard works well with linux cnc? The latency is good ?
Time to create page: 0.522 seconds
