Forum Header
Looking for advice? Is my DB25-1205 breakout board faulty?
7 years 11 months ago #121219
by uptown47
I haven't but I will.
The Z axis is working fine and is the same motor/driver as the others (and also on the same BoB).
I also had the X / Y working on the bench on that set up (admittedly many months ago).
Replied by uptown47 on topic Looking for advice? Is my DB25-1205 breakout board faulty?
andypugh wrote: Have you tried longer step times? That's a quick and easy test.
Go crazy, try 20,000 nS. (If that isn't long enough then the BoB isn't worth using)
7 years 11 months ago #121236
by uptown47
Just an update. This is turning into an interesting fault so I'll continue to post here just in case it helps someone else out in the future...
I changed the breakout board and had the exact same symptoms so it wasn't that.
I then set up a small bit of software that, I believe, was written by a guy called BigJohnT that tests the parallel port of the PC. I ran this through LinuxCNC and found that I couldn't switch on/off pins 2,3,4,5 of the breakout board.
I tried re-wiring some stuff on my machine (in case something was dragging it down) but to no avail.
I then changed the parallel cable for a different one and sure enough I could change signals on pins 2,3 which is the X axis (but not 4,5 - the Y axis?).
I then started StepConf and now can turn the X axis.
So... now I've got the X and Z working.
I tried taking out the PCI parallel port board (my motherboard didn't have a parallel port so I had to buy a PCI one) and re-seating it but to no avail.
I put my wiring back to original and X axis still works.
I swapped the parallel cable back to the original and X axis stops working...
So.... I've just ordered a new DB25 - DB25 male/male paralllel cable AND a new PCI parallel card (because I think this must be what's causing the Y axis fault).
They aren't due until Sunday at the soonest but, when I get them fitted, I'll report back.
Thanks again
Thanks again
7 years 11 months ago #121244
Replied by andypugh on topic Looking for advice? Is my DB25-1205 breakout board faulty?
Printer cables are not always fully wired (it's cheaper only to have the cores needed to print).
You need to be careful when buying DB25 cables that you get a fully-wired one.
The following user(s) said Thank You: uptown47
7 years 11 months ago #121252
by uptown47
Thanks Andy.
The thing that's been confusing me all along is that, previously, I had all the motors working with the same cable / PCI parallel card and breakout board.
When I built the control panel I just built it downstairs in my little computer room. But then I moved the lot and installed it upstairs in the attic (much to the annoyance of the Leader of the Opposition)....
I'll try the new cable and parallel board but I can see my having to buy a new breakout board as well. Time will tell.....
andypugh wrote: Printer cables are not always fully wired (it's cheaper only to have the cores needed to print).
Thanks Andy.
7 years 11 months ago #121361
by uptown47
Just a quick update..... the new "StarTech" parallel PCI-e card arrived on Saturday along with a new parallel cable (a day early!).
I fitted them and all the axis are working in automatic now! Although they drive really slowly and rough so the counts are obviously not set up correctly yet.
I didn't have a lot of time to work on it so was just pleased to actually see the axis drive (even if it was a horrible grinding slow drive).
Will carry on working on it this week after work and see where I get to but just wanted to report back that the problem must have been either the card or the cable (or both).
Thanks again for everyone's help
Time to create page: 0.143 seconds
