Remora - NVEM / EC300 / EC500
- BogdanTheGeek
- Thank you received: 6
08 Feb 2024 20:36 #292879
by BogdanTheGeek
Replied by BogdanTheGeek on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi All,
Has anyone posted any performance metrics for any of the ethernet boards?
I am working on something a bit crazy and I just wanted to get a baseline.
I would be interested in average UDP latency both ways. I know the servo thread is usually 1kHz, with some people going to 4kHz on actual servo systems, so I would assume that anything around the 100-200us should be good enough.
I expect that SPI PHY's, like the W5500, to struggle to get there.
I can provide some basic test code if people are interested.
Bogdan
Bogdan
- Fabien
09 Feb 2024 15:43 #292946
by Fabien
Replied by Fabien on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
thanks Tim
I have version 0.2.1 because the card is an NVEM v5.
I got this when flashing: C:\temp>pyocd flash ./remora-rt1052.bin --target mimxrt1050_quadspi
0001530 I Loading C:\temp\remora-rt1052.bin [load_cmd]
[======================================================= =] 100%
0038291 I Erased 196608 bytes (3 sectors), programmed 133632 bytes (522 pages), skipped 0 bytes (0 pages) at 3.55 kB/s [loader]
But now I can no longer connect to the network 10.10.10.10 -> linux shows that the cable is disconnected
- Fabien
09 Feb 2024 15:57 #292947
by Fabien
well I just tried version 3.1.2 and the network works.
Now remains the configuration of linuxcnc
- TimGow
- Thank you received: 3
09 Feb 2024 17:00 #292950
by TimGow
Replied by TimGow on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good to hear that you made it to the next stage.well I just tried version 3.1.2 and the network works.
- Fabien
10 Feb 2024 16:35 #293007
by Fabien
yes but now it's a tftpy problem which blocks me during the command: upload_config.py
- Fabien
11 Feb 2024 16:33 #293100
by Fabien
Well I think it's very complicated to set up Linuxcnc. I still have this tftpy problem when using upload_config.py. I saw that at the same time the folders and files in Scott's video really no longer correspond.
If anyone has any info for a noob like me
- BogdanTheGeek
16 Feb 2024 03:02 #293478
by BogdanTheGeek
Anyone?
- raf1110
- Thank you received: 5
16 Feb 2024 10:08 #293492
by raf1110
Replied by raf1110 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
read previous posts
- BogdanTheGeek
16 Feb 2024 11:28 #293499
by BogdanTheGeek
Thanks, but you could at least mention wether some has posted any metrics. If you were so kind to roughly estimate where those post might be, I would be even more appreciative.
I have searched though the threads and couldn't find anything.
If you think this is not a relevant topic to discuss it, please let me know and I will create a new one.
- Murphy
16 Feb 2024 17:36 #293530
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
@rbobey1989
Any sitrep? Where you able to get your encoder board up and running?
Time to create page: 0.271 seconds
