Remora - NVEM / EC300 / EC500
- raf1110
- Thank you received: 5
15 Jan 2024 13:49 #290756
by raf1110
Replied by raf1110 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Now I need to know how this can be done.
I hope someone will shed some light on how this can be fixed.
This will be last puzzle I hope.
- TimGow
- Thank you received: 3
15 Jan 2024 18:03 #290778
by TimGow
I followed a link back somewhere in the 150+ pages showing how to install Debian Bookworm for RPi4; I'll try to find a 'link to that link'.
Replied by TimGow on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
raf1110,Now I need to know how this can be done.
- TimGow
15 Jan 2024 18:58 #290779
by TimGow
raf1110,
Install Debian bookworm & Linuxcnc --> RPi4
docs.google.com/document/d/1S0K-UBlXnsYC...b_0/edit?usp=sharing
The following user(s) said Thank You: raf1110
- raf1110
15 Jan 2024 20:15 #290791
by raf1110
Big news.
MCUX had option to clear memory b4 flashing .bin which have removed incorrect uploaded JSON.
This allowed me to ping , serial print, and upload of correct files to board now all is left to setup on linuxcnc side.
so far so good.
Thanks all that helped.
so far so good.
- cncmiljc
16 Jan 2024 14:57 #290875
by cncmiljc
Replied by cncmiljc on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Scotta, could you send the latest stepgen DMA job files for the stm32F407? The ones you sent are not working.
- aol
17 Jan 2024 07:02 #290928
by aol
Replied by aol on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
hello,
i have also tried to setup an raspberry pi4b with linuxcnc 2.9.1 and nvem v2 5axis cnc board.
setup of rpi and flashing nevem is done like remora manual and should work, i can start remora-xyz and also become answer with ping on 10.10.10.10
but i can't unlock e-stop.
and also see no reaction on input and output pins.
can someone please help me and send me a working hal and ini file for my nvem v2 cnc board?
al
al
- raf1110
17 Jan 2024 14:20 #290953
by raf1110
Did you upload yourmachine.txt with tftpy?
Have you placed linuxcnc config files in correct folders?
I am stuck a bit in same place and have no response linuxcnc give me error missing remora-nv.so where I had halcompile eth3.0 there.
If you find solution for rt1052 chip NVEM my is v5 but it should not really matter.
Estop issiue could be your input is active high for active low configuration or opposite.
- aol
18 Jan 2024 07:49 #291002
by aol
hi raf1110,
i have nothing upload with tftpy becaus i thought if i install remora and copied standard .hal and .ini file in this directory the config is working...
the machine starts without any errors, but i can't enable the e-stop button on axis!
see also no reaction of other I/O ports in halshow.
i short the e-stop so as in mach3 (short stop imput pin to +12v NO switsch)
is there no .hal and .ini file where all I/O's and spindle and mpg pins working as on cover printed?
i hope my description is not to confused...
much thanks for your efforts in advance!
aol
aol
- aol
18 Jan 2024 09:23 #291009
by aol
have tried to install tftpy but not working...
cnc@raspberrypi:~$ pip install tftpy
bash: pip: command not found
cnc@raspberrypi:~$ sudo pip3 install tftpy
sudo: pip3: command not found
please help
please help
- dinamik
18 Jan 2024 11:23 #291014
by dinamik
Replied by dinamik on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Can someone post or upload a complete manual for linuxcnc+remora+bob+rpi
Required hardware:
Models and versions of controllers and their characteristics
Models and versions of supported RPI with best latency
Hardware for flashing
Other hardware for communication ie. for encoders and other stuf..
Required software & OS:
Linux distro and version for RPi
Linuxcnc and version
Flashing tools
Flashing files---with links for all BoB models
Other files....
Tutorial for wiring, instaling, flashing, cofiguration & everything else needed...
Thanks in advance
Required hardware:
Flashing tools
Other files....
Thanks in advance
Time to create page: 0.552 seconds
