Remora - Does Analog input syntax exist?
- Murphy
- Thank you received: 5
04 Jul 2023 14:15 #274746
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thanks zmrdko, I gave up , it was going to be thrown against the wall. I have python installed . I tried it through Linux aswell but none of the cmds worked.
- zmrdko
- Thank you received: 49
04 Jul 2023 15:22 #274752
by zmrdko
Replied by zmrdko on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
You probably dont have python installed.
You can try to download and install from here:
www.python.org/downloads/release/python-3114/
- Murphy
04 Jul 2023 15:26 - 04 Jul 2023 15:32 #274753
by Murphy
Python is installed , I used "py" instead of "python" in the command line. It installed pyocd also. but the flash CMD does not work. Iv also tried it on Linux. Flash command does not work. does not recognise Py, python,pyocd or python3 for the flashing
Last edit: 04 Jul 2023 15:32 by Murphy.
- tuxcnc
- Thank you received: 10
04 Jul 2023 15:33 #274754
by tuxcnc
It seems your very hard work is totally useless...
No guide, no docs, no examples (yes, it is one, but only 3 stepgens and nothing else)...
I bought EC500 and I don't know what the next...
Should I sell the board to some Mach3 user ?
I ordered two DAP devices (www.aliexpress.com/item/1005003056314140.html and www.aliexpress.com/item/1005005471801078.html probably I will get tomorrow).
These are different devices, which one I should use ?
How to upload firmware to board (Linux) ?
What I should do next ?
How to configure outputs and inputs in hal ?
I don't know even pins names...
How to configure Spindle PWM ?
I see there is "Spindle PWM" in ec500-rt1052.txt, but I know nothing else...
And last, but most important :
How to test your project without basic knowledge about it ?
Replied by tuxcnc on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi.
- zmrdko
04 Jul 2023 17:37 #274761
by zmrdko
Easy man. Scott is doing outstanding job for free, so at least be respectful.
Linuxcnc is not plug and play system so don't expect everything to be ready in 5 minutes.
If you would take your time going through this thread you would find a youtube video for flashing guide:
Rest of the questions are related to linuxcnc configuration, which has nothing to do with remora firmware itself.
The following user(s) said Thank You: tommylight, meister
- tuxcnc
04 Jul 2023 18:10 #274768
by tuxcnc
If you do anything, do it good.
If you do something that does not work, there is no reason to be gratitude, even when you do it for free.
NO.is doing (...) job for free, so at least be respectful.
- Thank you received: 6972
04 Jul 2023 18:22 #274769
So, that begs the question:
What did you do that is good in any way shape or form for others? For free, that cost you a lot of time and trouble to do good. Anything?
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I absolutely agree.If you do anything, do it good.
- Murphy
04 Jul 2023 18:31 - 04 Jul 2023 18:33 #274772
by Murphy
Dude that's bang out of line. He has a full time job, and probably a family.He does this for free , for the community in his spare time.Thats a good thing. Im only learning, and I get frustrated when things don't work, but that's my fault from lack of knowledge. Download the Linuxcnc manual, you will learn a lot from it. if you want things to just work spend money on another suite like centroid CNC , mach4 etc
Last edit: 04 Jul 2023 18:33 by Murphy.
- cncmiljc
04 Jul 2023 19:13 #274778
by cncmiljc
Replied by cncmiljc on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Is anyone seeing the guy forcing someone to use remora? the answer is no, so if you buy a board and want to do the tests and you can't get anywhere, the problem is all yours, the guy takes his time to do something, puts it here for free and still has people to complain, this world is really lost, if you don't like something, do it yourself, simple as that.
- Aaroncnc
- Thank you received: 45
04 Jul 2023 19:18 - 04 Jul 2023 19:21 #274779
by Aaroncnc
Replied by Aaroncnc on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
In regards to pin names my suggestion is to use the built in linuxcnc parallel port config creator and set it up for your machine.
Then copy the pins for the io and other bits into the remora config.
Then just replace the parallel port pin names with the remora ones.
Understand you are asking for alot of a what I would call alpha stage project.
Once it gets it's into late beta is when it will have more hand holding guides and configs for users of lesser abilities.
To find the pin names if they are not spelled out for you just read the code to find them.
If you are unable to grasp even the ability to read code I suggest you wait or try a different solution.
remora-docs.readthedocs.io/en/latest/
This is the documentation for the spi version of remora that uses 3d printer main boards.
This may give you an idea of pin names.
I use this version and not the ec500.
Last edit: 04 Jul 2023 19:21 by Aaroncnc.
Time to create page: 0.711 seconds
