Remora - NVEM / EC300 / EC500
13 Mar 2024 10:44 - 13 Mar 2024 10:45 #295816 by vpomerleau
Replied by vpomerleau on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thank you Cold Turkey Your tutorial is awesome, I can now flash the board in seconds using standard stlink. The erase function return error in attached picture but I just overwritten the firmware  and it did work. The only thing in your tutorial that didn't work right out of the box was lsusb command, I had to instal usb utils using these commands
installati.one/install-usbutils-debian-12/
Thanks again
Last edit: 13 Mar 2024 10:45 by vpomerleau.
13 Mar 2024 10:52 #295817 by Cold Turkey
Replied by Cold Turkey on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
You are very welcome, I'm glad it helped someone.
Thanks for pointing out the usbutils issue. I have usbutils installed in step 1 but didn't consider people starting at steps further ahead. I will be sure to include reference to it again.
Also thanks for all the work you did with the full config. I have emailed it to Scott as well as posted him another EC500 to work with as he also had issues with some of his MPG pins not working.
13 Mar 2024 10:54 #295818 by Cold Turkey
No idea on the error you were getting with the erase sorry. Way above my pay grade.
The following user(s) said Thank You: vpomerleau
14 Mar 2024 02:48 #295870 by cncmiljc
What program are you using to write the rt1052 firmware on the boards?
14 Mar 2024 06:32 #295877 by Cold Turkey
Pyocd
15 Mar 2024 00:36 #295928 by cncmiljc
Is anyone using a program other than this Pyocd?
15 Mar 2024 00:51 #295929 by Cold Turkey
Mate, on the previous page vpomerleau states he uses MCUExpresso and this is what plenty of previous people have tried.
Don't want to sound rude but you really need to read through the thread. People have been posting what they have used and the issues they've had. Pyocd is used because it is what we've had the most success with.
The following user(s) said Thank You: raf1110
15 Mar 2024 02:05 #295931 by cncmiljc
Thank you very much for your quick response and attention.
17 Mar 2024 22:30 #296156 by vpomerleau
Hi everyone
I added a hall sensor to my spindle so I can do closed loop on the spindle of my mill, it's wired to the index pin. Does someone have done closed loop on the spindle with remora? On the top of that I have 2 gears on the spindle. Does someone have a Hal file that might work for my configuration. . I'm having a hard time finding about this on the other threads and I read this one like five time from start to end. Remora is a different beast than mesa cards. Thank you
17 Mar 2024 22:36 #296157 by Cold Turkey
Did you have this working on a Mesa card?
Time to create page: 0.223 seconds
