Remora - NVEM / EC300 / EC500
- spdbmp927
- Thank you received: 5
19 May 2022 18:12 #243354
by spdbmp927
Replied by spdbmp927 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I added more printfs and recorded this:
joint 2 frequency command: 16777215
frequency command pointer: 16777215
frequency command pointer: 536872064
rxData frequency command: 16777215
rxData frequency command pointer: 536872064
rxBuffer frequency command: -1
rxBuffer frequency command pointer: 536871996
This suggests that the copy from rxBuffer to rxData is being interrupted by a read event.
The following user(s) said Thank You: royka, Domi
- scotta
- Thank you received: 480
20 May 2022 23:01 - 20 May 2022 23:03 #243445
by scotta
Some really interesting and useful observations and fault finding!!!
The udp_data_callback() is running in the main loop, with the threads running in interrupt context. If a thread ISR is triggered during the call to the callback then it would be possible for the data move to be interrupted by a memory read.
Implementing a mutex for the data buffer would be the solution if your theory is correct. And probably a good feature anyway.
The may also explain why the SPI version of Remora has not seen this issue as DMA is used to move data with the memory management ensuring that only DMA or the CPU accesses memory at a time.
Last edit: 20 May 2022 23:03 by scotta.
- scotta
21 May 2022 04:11 #243458
by scotta
IT'S FIXED!! .... well it looks like it.
A huge thanks to spdbmp927 for working out that it was a corrupted rxBuffer. I have pushed a bug fix to the develop branch. I've run Roy's gcode file, which before would cause lots of following error spikes, successfully with a very small follower error setting. And this is at +400% normal speed.
The fix was as simple as disabling interrupts when moving the rxData into the rxBuffer.
Would be great to get feedback from others if this issue is now resolved.
Thanks again spdmbp927!!
The following user(s) said Thank You: tommylight, royka, Domi
- royka
- Thank you received: 127
22 May 2022 13:57 #243559
by royka
Replied by royka on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Yes I can confirm that it's fixed. I'm really glad you both found and solved the problem!
- Win_D
22 May 2022 22:04 #243578
by Win_D
Replied by Win_D on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Scotta,
Were the master branch implement C Axis? I tried XYZABC configuration and saw C Axis pulse/dir were not there.
BR
Win
BR
Win
- scotta
23 May 2022 22:54 #243653
by scotta
Opps, yes there is an error in the master branch, line 259 in main.cpp. Looks like a hang over from testing. Not to worry. I'm going to merge the develop branch into main hopefully today. This will make using the configuration file the standard way to set-up the NVEM.Hi Scotta,
BR
Win
- scotta
24 May 2022 15:22 #243697
by scotta
For those monitoring the dev branch, I've pushed a new update that includes a default configuration. This implementation presents 3 joint stepgens and no IO so that people can know the board is up and running when first set-up. Alternatively this could be a full config if people would think this is more appropriate. The intention is to merge dev into main and create a release now that bugs have been resolved.
- scotta
25 May 2022 03:27 #243753
by scotta
Remora-NVEM 1.0.0 has been released. Thanks to everyone for testing and helping with the beta bug fixes.
github.com/scottalford75/Remora-NVEM/releases/tag/1.0.0
For those not wanting to worry about the source, the bin file is github.com/scottalford75/Remora-NVEM/tree/1.0.0/Firmware
I have received another NVEM board (I killed the PWM output on the test board) and will use this to make some short YouTube videos on how to flash the firmware and get LinuxCNC up and running with the board.
I'd like to step through the LinuxCNC configuration setup (ini and hal) for the different features such as setting up and e-stop, end stops, spindle etc. If you have a running config for some of these, please share them here so we can consolidate into a working example to help people get up and running.
The following user(s) said Thank You: phillc54, tommylight, daiman444, royka
- Win_D
25 May 2022 04:26 - 25 May 2022 04:32 #243758
by Win_D
For those want to run B and C Axis.
Not sure if all NVEM V2 are the same in pul/dir pins, for my PCB, B and C Axis as following:
B step: PE_7
B dir: PE_6
C step PE_5
C dir PE_4
I downloaded this config and all XYZABC were running fine.
B step: PE_7
B dir: PE_6
C step PE_5
C dir PE_4
Last edit: 25 May 2022 04:32 by Win_D. Reason: attached image data display wrong
- Aaroncnc
- Thank you received: 45
25 May 2022 13:16 #243791
by Aaroncnc
Replied by Aaroncnc on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Scott,
Spi vs Ethernet.
I have a Ethernet module that I could connect to my 3d printer main boards. Any advantage vs using spi?
The main one I can think of is the com is less sensitive to interference. And not limited to devices with spi support.
Any other reasons?
Spi vs Ethernet.
Any other reasons?
Time to create page: 0.240 seconds
