10.5 x 25 cnc plasma table retrofit
2 years 23 hours ago #313581 by tcbmetalworks
Do you have any recommendations for wiring this whole thing? Should I mount the controller with the drives on the gantry itself? Or do I run wires threw the cable chain from controller to drives. I have concern the ht2000 will put out alot of high frequency interference. If I keep the original motors and drives I would like to keep atleast the drives mounted to the gantry so I can use the original wiring that is rf sheilded. Is there any parasitic loss on long distance runs that should be avoided by mounting controller to gantry. I think I would prefer not to mount the computer to the gantry it seems dangerous to me, but I might require a long range or wireless pendant otherwise. Maybe it's better to keep it all on the gantry. I still have not decided. Do you have any recommendations for sources for high rf sheilded cable? And what is your preferred type of wire. I've used alot of cheap wire before and had it corroded apart on other projects. Leading to endless wiring issues, I am building this machine In hopes I will run it often I want reliability and my shop is a hard atmosphere for a machine lots of dust and humidity/water from leaks.
2 years 23 hours ago #313583 by tcbmetalworks
If i was to mount computer with controller to gantry would you recommend going with a sealed industrial fanless type computer I found a few on ebay for a couple hundred bucks. My last plasma table is a 4x10 I built with mach 3 and windows 7. I found the operating system to be highly unstable computer would crash or freeze, and I seen what kind of damage was done by the plasma dust. My other concern would be for shielding I here that these style of computers have a increased protection against rf interference and I know that the ht2000 will put out alot compared to my cheap everlast 102i blowback style. There is a few features I would like to have aswell on the Linux cnc side of things do you know if I can set up plate centering? Possibly amperage adjustment remotely. Do you have any other recommendations for scripts I can add to really trick this puppy out. I am new to linux cnc but trying to obsessively learn as much as I can, it seems like the best option open source.
2 years 23 hours ago #313585 by tommylight
It is a heavy gantry, so adding 10-15KG of other stuff will not change much in mobility, so yes, mount everything on the gantry, including the PC. You do not want to run 15 meters to press ESC when needed! :)
Also, plasma so a lot of interference, and shorter wires help a lot in mitigating that.
Use existing cabling, usually very high quality and good shielding.
Here are some ideas
forum.linuxcnc.org/show-your-stuff/47357...sma-cutting-machines
2 years 22 hours ago #313588 by tcbmetalworks
I also have a 1980s toyoda horizontal machining center complete with pallet changer and tool changer. Would this be another machine that's a good candidate for retrofit is linux cnc able to control the tool changer and pallet changer? Can you account for tool wear in Linux cnc? It's currently on a fanuc 11m control. It's a beast of a machine just little lacking in capabilities compared to modern machines and all coding is done by hand due to lack of memory.
2 years 22 hours ago #313589 by tommylight
Yes, yes and yes.
I might be a bit biased as i have twice retrofitted fully working machines, so i do not care what was, i know what it will be when i get my hands on it = LinuxCNC.
We have 15 ton machines working with it, no idea how heavy was one i saw on youtube but a human was puny standing in it.
It just takes time and effort and you will be left with huge knowledge you gathered on the way.
2 years 3 hours ago #313641 by tcbmetalworks
Not much progress made on plasma table today but started welding up a horizontal sheet metal rack based on lazer bros plans. I've been storing verticaly and it's a pain and dangerous to set the sheets down on the table like that. I've had my guy cleaning the rails on the plasma table using a wire wheel then when I set them all up going to try to stone any high spots. Do you know of any good literature to study up on for setting up these gantry style tables? Specificly in keeping the rails parallel and level. I'm sure there's tricks with lasers and string bobs etc.
Time to create page: 0.279 seconds
