- Thank you received: 994
Bloumielies wrote: Hi John
Yes, precisely the way that is explained on the website. I also found now that the engrave.py does the same.
Thank you
Thank you very much, it seems to work now 100%. Appreciate it.
Maybe just a remark. I see the cutter does not clear the arc when finished with the cutting. Suggestion if I could maybe to just clear the work piece after cutting.
I will test the others now and get back if I see some other errors.
Thank you
The following gives me the same error as before on the arc buddy about the no percent sign and program end:
1. boltcircle2
2. counterbore
3. drill
4. engrave-11
The ones not mentioned works correct.
Kind regards
