During start i get this error USRMOT: ERROR: command timeout
6 years 5 months ago #169015 by Korbi
Hi
i try to build my first NC with LinuxCNC
i want to start with some real basic configs.
but when i try to start my machine i get this log:
Machine configuration file is 'Test_Maschine.ini'
Starting LinuxCNC...
Found file(REL): ./Test_Maschine.hal
Note: Using POSIX realtime
emcMotionInit: emcTrajInit failed
Config is is in attachments
can someone help me to start LinuxCNC
The following user(s) said Thank You: bbsr_5a
6 years 5 months ago #169060 by bbsr_5a
Welcome
did you firer up a simulation machine First
its a simple XYZ setup
so why did you choose to go for 2.9 insted of just doing the Debian Stretch iso with 2.7.15 on it
6 years 5 months ago #169067 by Korbi
i am able to start sim machines, like the axis_mm and so on.
I followed a tutorial and get Linuxcnc 2.9.
When nessesarry i can switch to 2.7
You say:
Testmachine hal is empty, what should be inside for a test start?
6 years 5 months ago #169104 by tommylight
6 years 5 months ago #169710 by Korbi
Thank“s very mutch,
now LinuxCNC is starting.
But i fail into the next problem.
I can not reset the e-stop and turn "on" the Machine.
Time to create page: 0.083 seconds
