Limit Switches, EStop and Spindle
5 years 9 months ago #196201
Replied by tommylight on topic Limit Switches, EStop and Spindle
Check the input pins on the hal show, pins>parport>inputs...
5 years 9 months ago #196203
by Marsbar
Replied by Marsbar on topic Limit Switches, EStop and Spindle
There doesn't seem to be an option for 'input' here!
The path I have got (below) is pins>parport>0 and the list of pins
Notably perhaps the Dir is listed as 'OUT'!
(and all the pins listed here say the same - Dir - OUT)
They also say under OWNER: '10'
Does this mean somehow they have got linked to pin 10 by mistake
or am I barking up the wrong tree?
5 years 9 months ago #196208
check the
pin-10-in
and
pin-10-in-not
on watch tab while toggling the switch
pin-10-in
and
pin-10-in-not
5 years 9 months ago #196210
by Marsbar
No response on the watch tab either.
5 years 9 months ago #196212
Leave LinuxCNC as is monitoring the pins, disconnect the DB25 from the PC, locate the pin 10 on the parallel port on the PC, insert a short wire in and touch it to the metal shield of the connector while watching the LinuxCNC.
5 years 9 months ago #196216
by Marsbar
Hi again,
Just done as you suggested on the parallel out of the PC and there is no response from the pins on HAL Watch
