Modbus communication error
6 years 9 months ago #155241 by cmorley
Replied by cmorley on topic Modbus communication error
Looks from your setup software that the function should be 3 (read hold registers)not 4 ....
6 years 9 months ago #155244 by jsskangas
I did try 3 (read hold registers) and it did not make any difference:
Serial reading...
5 chars found
INFO CLASSICLADDER- Modbus I/O module received: Lgt=5 -> (Slave address-1 - Function code-83 ) 2 C0 F1
ERROR CLASSICLADDER- MODBUS-EXCEPTION RECEIVED:83 (Excep=2)
ERROR CLASSICLADDER- MODBUS-INCORRECT RESPONSE RECEIVED FROM SLAVE!!!
Serial flush all!
INFO CLASSICLADDER- Modbus I/O module to send: Lgt=8 <- Slave address-1 Function code-3 Data-8 34 0 1 C7 A4
INFO CLASSICLADDER- MODBUS Length we should receive=4 (+3)
Serial config...
Serial writing...
Writing done!
select() for serial reading...
Serial reading...
5 chars found
Serial flush all!
Serial config...
Serial writing...
Writing done!
Serial reading...
5 chars found
Serial flush all!
Serial config...
Serial writing...
Writing done!
Serial reading...
5 chars found
Serial flush all!
6 years 9 months ago #155245 by cmorley
It did make a difference - the exception code is now 2 - illegal data address
So the function (3) is corrected but seems the address is wrong
is address 2101 legal? in your test you used 2100
6 years 9 months ago #155246 by cmorley
ahh I bet you did set 2100 in classicladder - try setting 'modbus element offset' to 0
Chris
6 years 9 months ago #155247 by cmorley
Sorry I meant set offset to 1
6 years 9 months ago - 6 years 9 months ago #155248 by jsskangas
Hello
2100 and 2101 are correct. i tried them both, in hex value and in decimal.
I also tried different offsets 0-9. none made difference.
Last edit: 6 years 9 months ago by jsskangas.
