- Thank you received: 267
Gildemeister NEF 480 Retrofit
5 years 7 months ago #201395
by anfänger
Replied by anfänger on topic Gildemeister NEF 480 Retrofit
You know it’s cold when you need a hear gun to warm up the rubber seals to be able to get the cable trough.
I am looking forward to a bit warmer weather.
5 years 7 months ago #201399
by J Green
Replied by J Green on topic Gildemeister NEF 480 Retrofit
Seems as if the cold bothers me more the older I get .
To heat soak equipment , used to make 3/4 inch electrical tube frame and cover it with plastic 50mil thick building foil wrap . Was cheap and easy to drape over the temporary metal tube frame . Added electric heater and a fan . Can also be used for spray painting booth .
When it's freezing don't lick flag poles
Bob
Bob
5 years 7 months ago #201406
Replied by tommylight on topic Gildemeister NEF 480 Retrofit
Last two winters were mild here so not much of pole licking going on.
5 years 7 months ago - 5 years 7 months ago #201407
by anfänger
The mean thin is thee weeks ago we hat -10° two weeks ago 18° So now I think it should be warm when it’s sunny outside but it is 0°.
And I am getting old and start complaining about everything...
Last edit: 5 years 7 months ago by anfänger.
5 years 7 months ago #201716
by anfänger
5 years 7 months ago #202029
by anfänger
Time to create page: 1.168 seconds
