It looks like the only standard bitfile with PWM on Pin1 is DMMBob, and that has the step and direction pins switched compared to what you need.pacman13b wrote: ended up with with the prb_rfx2 pin file flashed to mesa, but it seems like it is missing pwm on pin 1
That ought to be fairly easy, you just need to link a GPIO pin. However pin 14 on the RF1 bitfile is set up as the spindle PWM, so only becomes available as GPIO if you set num_pwmgens to zero in the config.and I couldn't program an enable pin for the drives also.
What sort of "not good" ? Depending on the drives you may need to invert the step pins to get the right sort of drive signal. Otherwise look at that step time setting.After manually enabling the drives I had some motion on axis x,y,z.but not good.
