- Thank you received: 75
Spinx1 to 7i85
11 years 5 days ago #64351
by OT-CNC
Replied by OT-CNC on topic Spinx1 to 7i85
An option I didn't consider is the secondary 26 pin connector on the 5i25 (P2) as it will be a messy wire termination inside the pc without some screw terminals to mount to.
Can I get the required pwm out on that connector without firmware change?
11 years 5 days ago #64352
No, you still need a firmware change. At the moment the internal connector is configured for a second 7i85S with Step/Dir.
To wire neatly to that internal connector you need: store.mesanet.com/index.php?route=produc...74_79&product_id=235 or from a non-mesa source: www.amazon.com/CableWholesale-Motherboar...ds=parallel+port+idc
Replied by andypugh on topic Spinx1 to 7i85
OT-CNC wrote: Can I get the required pwm out on that connector without firmware change?
11 years 5 days ago #64353
by OT-CNC
andypugh,
Thanks for the clarification on that. I was about to start wiring lol...
Okay, so in that case I will need a new configuration and will wire to the 7i85 as originally intended.
The 5i25 manual shows a JTAG connection for programming. Do I need to get that connector for updating the firmware???
11 years 5 days ago #64354
No, you can re-program in the PC with the "mesaflash" utility.
Instructions are in the 5i25 manual, Page 12: www.mesanet.com/pdf/parallel/5i25man.pdf
OT-CNC wrote: The 5i25 manual shows a JTAG connection for programming. Do I need to get that connector for updating the firmware???
10 years 11 months ago #64935
by OT-CNC
Hi PCW,
I'm sorry to be a pain about this. Any updates on the firmware progress?
Thanks again for your time, your help is much appreciated.
10 years 11 months ago #64947
Replied by PCW on topic Spinx1 to 7i85
freeby.mesanet.com/5i25_7i85sspx2.bit
has the 4th stepgen replaced with PWM and DIR
The following user(s) said Thank You: OT-CNC
Time to create page: 0.079 seconds
