Having trouble getting the 7i84 working. I've got a red light on CR6 and trying to connect with mesaflash gives me this error.
mesaflash --device 7i84 --readhmid
( or mesaflash --device 7i84 --addr 10.10.10.10 --readhmid ??)
ERROR: Unsupported device 7I84
or with newer mesaflash from
github.com/jethornton/mesaflash
./mesaflash --device 7i84 --readhmid
(or mesaflash --device 7i84 --addr 10.10.10.10 --readhmid ??)
No 7I84 board found
I've got all power in pins connected to 12v. (and gnd to gnd)
The manual says: CR6 Red Lower left Field I/O fault
It doesn't matter if LinuxCNC is running or not.
I have nothing set up yet, just trying to get all the cards running.
Can't find a solution with google.
The 7i92 has been flashed with 7i92_7i77_7i74D.bit (correct firmware?)
Both 7i92 and 7i74 have their own 5V supply.
I have tested a few different network cables, none are crossover.
Sserial has been installed for the 7i84.
I'm sure I've missed something..?
