Mesa 7i96 Output Wiring
6 years 2 months ago #178034 by AgentWD40
Replied by AgentWD40 on topic Mesa 7i96 Output Wiring
I appreciate the answer but now I'm even more confused...
Using this pic can you connect all the necessary wires that are needed to safely run a relay module of this type?
image missing https://i.imgur.com/ZwsL3Vs.png
6 years 2 months ago #178036 by PCW
Replied by PCW on topic Mesa 7i96 Output Wiring
Look like it would be wired
+24V --> DC+ 7I96 OUT+
0V --> DC-
7I96 OUT- --> IN
Though a plain relay would be sinpler
The following user(s) said Thank You: AgentWD40
6 years 2 months ago - 6 years 2 months ago #178037 by AgentWD40
Like this? Also, can you specify a plain relay you would prefer?
image missing https://i.imgur.com/0LFIjMf.png
Last edit: 6 years 2 months ago by AgentWD40.
6 years 2 months ago #178039 by PCW
I was thinking of simple DIN rail mounted relays but they seem to be more
expensive unless you buy direct from China
6 years 2 months ago #178098 by Mud
Replied by Mud on topic Mesa 7i96 Output Wiring
PCW wrote: Both are correct.
If you use the second scheme you should definitely fuse the 24V supply
since a short to ground (assuming 24V common is ground)
would likely damage the 7I96 output
Note that you should have flyback diodes across the relay coils
Am I correct thinking the diode positive (striped end) should go to 7i96 OUT+ (and can put the diode negative to OUT-)?
6 years 2 months ago - 6 years 2 months ago #178100 by PCW
No, the diode should be across the relay coil
for example
Sourcing drive:
+24V --> OUT+ --> OUT- --> COIL+ --> COIL- --> GND
or
Sinking drive:
+24V --> COIL+ --> COIL- --> OUT+ --> OUT- --> GND
Diode always goes from COIL+ to COIL- (cathode=band to COIL +)
If you are unsure, test the relay+diode with a mechanical switch
replacing the 7I96 OUT+- pins
Last edit: 6 years 2 months ago by PCW.
Moderators: PCW, jmelson
Time to create page: 0.672 seconds
