hilo90mhz wrote: Oh and I did also just remember that I could use these DC drives in torque mode by disconnecting the tachometers. Someone did this with a Kflop conversion of the same mill with the same drives - by cutting a resistor lead and soldering a wire onto said resistor past the velocity feedback loop on the drives.
Does anyone have insights on if I would be better off bypassing the tachometers like this?
andypugh wrote: I think that, compared to my lathe, it is harder to use the marks than to use the full-absolute emulation.
andypugh wrote: Using the position.txt data from the previous run, the system acts much like with the marks you describe, except using the shutdown position in place of the mark.
This will only work for Z if the head does not drop after linuxCNC exits.
Just don't?hilo90mhz wrote: This sounds better than nothing
but what If I spin the motors a little by hand while it is off?
What I have for my lathe is an alternate INI file that sets things up with conventional homing. If I lose home (through something going wrong which leads to the position.txt file being wrong) then I re-start the machine from that config and home conventionally.theres no way to find that exact home position ever again which isnt good enough for me
Edit: Okay I realized my mistake - this is not the firmware source but the driver source that runs on the LinuxCNC computer and interacts with the firmware on the Mesa 7i49..andypugh wrote: Here is the code:
github.com/LinuxCNC/linuxcnc/blob/master...mot2/resolver.c#L354
Awesome! I'm still wrapping my head around how all the different layers in LinuxCNC interact but may take you up on that if its the easiest solution. I will get back to you once I've gone through the setup and understand how the entire LinuxCNC environment works more if this turns out to make the most sense vs using the M100-M199 script method to set it.andypugh wrote: If it looks like toggling the use-position-file input (internally called use-abs) would do what you want then it is relatively easy for me to change that parameter to be a full HAL pin.
