hilo90mhz wrote:
Edit: Okay I realized my mistake - this is not the firmware source but the driver source that runs on the LinuxCNC computer and interacts with the firmware on the Mesa 7i49..andypugh wrote: Here is the code:
github.com/LinuxCNC/linuxcnc/blob/master...mot2/resolver.c#L354
I had just found that repositoryandypugh wrote: Yes, you need to look here for the Mesa source:
github.com/LinuxCNC/hostmot2-firmware/bl...ter/src/resolver.vhd
(And this firmware would run on the 6i24, the 7i49 is essentially passive)
Of course you are right! and I knew that just wasn't thinking about it fully..andypugh wrote: (And this firmware would run on the 6i24, the 7i49 is essentially passive)
hilo90mhz wrote: I had just found that repository
- I notice the most recent commit is 4 years old, does that mean there have been no updates to the firmware since then? or just not merged from some upstream Mesa source?
If you keep them fairly short there appears to be little trouble.Do you recommend using shielded 50 pin IDE cables? for connections between FPGA and daughter boards?
hilo90mhz wrote: I the tachometer commutator is not concentric with the shaft
But bad news is the bearings inside resolver are totally gone.
