7i77 and single ended MPG-Wheel encod er - read-out problem
5 years 1 week ago - 5 years 1 week ago #224003 by Baderbahn
Ah, so I don't need a mux4- element ?
Just net the hm2_5i25.0.7i77.0.0.enc0.count ?
Edit:
I tried the following:
Set 7i77 to Mode 3 by
sserial_port_0=003xxx
and connect the signal
net axis-selected-count    <=    hm2_5i25.0.7i77.0.0.enc0.count
but get an error "pin doesn't exist"
so I'll try to figure out by searching halshow, which pin it is  :P
Edit 2:
Note to myself: I'm stupid. It should be [...] 300xxx[...] istead of [...]003xxx[...}
I am able to read the count now! thank you very much, PCW !
Last edit: 5 years 1 week ago by Baderbahn.
5 years 1 week ago #224028 by PCW
The mux4 is used to select the jog increments
5 years 1 week ago - 5 years 1 week ago #224031 by bevins
Put this in your custom.hal. It should get you a working mpg using enc0. You are using 7i77 you you will need to change to suit your mesa setup.
Last edit: 5 years 1 week ago by bevins.
Moderators: PCW, jmelson
Time to create page: 0.373 seconds
