7C81 - It appears that I have the wrong BOB, what now?
3 years 4 months ago #274416 by MrRekt
That's disastrous news!
But I suppose it's a watertight answer for my problems...
I don't suppose you have any insight as to when the 7C8x will be back in stock, would you?
3 years 4 months ago #274417 by PCW
We will have the 7C81T later this year
plus we may have a few boards with solder issues
that can be fixed
It's likely your 7C81 is repairable
Most like U1 is damaged
(Usually from high negative input currents damaging the input clamp diodes)
You can check by measuring the voltage across C14, it should be ~4.2V
Another option is to use P2 instead
3 years 4 months ago #274418 by MrRekt
I'm measuring:
24.7mV across C14
4.12V across C15
4.16V across C32
I removed the Pi and checked all GPIO on P2 and P7. They read 5V across the board.
3 years 4 months ago - 3 years 4 months ago #274419 by PCW
That is evidence that the 74CBT16211 (U1) has been damaged.
Last edit: 3 years 4 months ago by PCW.
3 years 4 months ago #274420 by cakeslob
I like the sound of 7C81T,
are you keeping the RPI header the same as the original?
3 years 4 months ago #274425 by MrRekt
I tried to do exactly that - but instead of continuing to struggle, I thought I'd ask for a hint for how I'd do this. (I think it's reasonable to assume I'm doing it wrong.)
Moderators: PCW, jmelson
Time to create page: 0.061 seconds
