Xilinx Setup to edit config for 7i92T
1 year 10 months ago #316615 by StoneB
You have the old (G540) package name in your pinout file
While copying the file for pasting I noticed that while I had changed the package name at the start of the file, I had forgotten to change it at the end...
It compiles!! I'll flash it tomorrow image missing /media/kunena/emoticons/cool.png
Thank you for all your help!
1 year 10 months ago #317571 by StoneB
Sorry @PCW, I need to request your help once more... I tried flashing the bin file with
sudo mesaflash --device 7i92T --addre 10.10.10.10 --write 7i92t_slidersfg.bin
and I get
Error: Wrong bitfile destination device: Trion, should be T20F256
Should I have set somewhere in Efinity the type of board used? I started simply from the 7i92t.zip, taking the 7i92t_G540x2_34 file as basis...
1 year 10 months ago #317572 by PCW
That most likely means you don't have a very recent mesaflash installation.
The bin file header parsing was changed on more recent mesaflash versions
to accommodate longer path-names (the build path-name is embedded in
the .bin file header)
1 year 10 months ago #317577 by StoneB
Victory! (of step 1, now I move on to step 2, building my HAL image missing /media/kunena/emoticons/cool.png)
I am using the Raspi build ( forum.linuxcnc.org/9-installing-linuxcnc...erry-pi-4b-5?start=0 ), but after recompiling mesaflash from git it worked flawlessly!
Thank you so much for guiding me along!
Moderators: PCW, jmelson
Time to create page: 0.315 seconds
