esab ultrarex retro fit plasma / flame cutter
14 years 5 months ago #20094 by jd896
The voltage varies dependant on how close an object is to the sensing ring on the torch Also I'd there any chance anybody would recognise these drives having a hard time finding the enable for them
14 years 5 months ago - 14 years 5 months ago #20095 by jd896
forgot the photo image missing http://linuxcnc.org/media/kunena/attachments/legacy/images/photo.JPG
Last edit: 14 years 5 months ago by jd896.
14 years 5 months ago #20096 by BigJohnT
First thing I would do is eliminate as many possible wires as you can. Then try and trace back the ones you have left to see if you can discover what they do. Also the enable might be "on" and readable with a meter when jogging slow where the velocity input voltage would vary with speed.
14 years 5 months ago #20097 by jd896
Hi John
Yeah that controls given up entirely now so no jogging or anything now I did find the enable to be as I remember 10 volt I just carnt think where it was
From pin 1 they are as follows
0 volt
33 volt (servo power)
10+\-
Unknown
Unknown
Unknown
Pin 7 I think was the enable but there's a minus 13volt there
10+\-
Unknown
Clutch supply 24v dc
Earth
14 years 5 months ago #20098 by jd896
found this in my emails thins pcb had to be repaired conecter x17 and 18 go to the drives
File Name: Nce500.pdf
File Size:266.25 KB
14 years 5 months ago #20145 by PCW
Does the capacitive sensor go to the board in the schematic? (unfortunately that schematic is pretty fuzzy especially signal names)
Time to create page: 0.236 seconds
