esab ultrarex retro fit plasma / flame cutter
14 years 5 months ago - 14 years 5 months ago #20160 by jd896
Unfortunately no however I have found the activation wire for the hight control an wires to rase the tourch for clearance this will do for now I think I may just have to build a z axis could then maybe do a scriber atachemnt for it also but for now I really need to get this machine making money again on the upside u have the drive wiring sorted pin five was the enable an I have the x axis running needs tuneing now but I have also killed the y axis servo drive fiddling with the enable, wasn't being carful enough so that's gone for repair hopefully be back soon
Thanks guys getting excited again now I've seen movement once more
Last edit: 14 years 5 months ago by jd896.
14 years 5 months ago - 14 years 5 months ago #20316 by jd896
im still wating on the drive coming back however i carnt seam to get my limits showing properly i carnt seam to inver the input without an error what is the corect term (the limits are nc curcuit)
also when i try the calibration in axis i get the follwing error the basic config was done in pncconf and now im trying to hand edit this i have tried to invert the pins in pnc but it has no effect somehow
much thanks guys
File Name: TUNING_LOG_.txt
File Size:521 B
14 years 5 months ago #20317 by cncbasher
to reverse the sense of the inputs add ' _not ' to the pin name for example ... hm2_5i20.0.gpio.036.in becomes when inverted hm2_5i20.0.gpio.036.in_not
you say you have the limits wired normaly closed .. is the switched connected to ground ? or to 5v ( they should be to ground )
mesa default interfaces is as i understand it pulls the inputs to 5v when switches are open , so you need to pull the switch to 0 volt when closed
if the switch is to 5v then operating the switch will have no effect . as the pin is already at 5v
14 years 5 months ago #20319 by jd896
thanks cncbasher just sorted it the input pins don't seam to got in the order i thought they did ended up watching all the pins on the card and just edited as needed also found the invert code just after i posted sods law
thanks tho does anybody have any clue about the error i get when trying to calibrate the log file above
14 years 5 months ago #20320 by jd896
can't read "ininamearray(0)": no such variable
this is the error i get when trying to calibrate also the boxes in the calibration window are blank/missing i.e. no hal values and names and such
as i said the first config was produced with pncconf am i better posting this problem the that section of the forum ?
thanks guys getting there slowly
14 years 5 months ago #20321 by cncbasher
i presume this is within the servo setup in pncconf ? , i believe this part may not be working , therefore you'll need to hand edit .
Time to create page: 0.456 seconds
