- Thank you received: 994
Rebuilding a CHNC I Collet Closer
16 years 7 months ago - 16 years 7 months ago #2438
by BigJohnT
Replied by BigJohnT on topic Re:Rebuilding a CHNC I Collet Closer
The worn part that I replaced from McMaster Carr. I have a lifetime supply of everything except the large Quad Rings.
image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/collet07.jpg
- 2pcs 9452K18 AS568A - 016 O-Ring
- 2pcs1879T23 AS568A - 010 O-Ring
- 1pc 5308T233 AS568A - 166 O-Ring
- 2pcs 90025K617 AS568A - 261 Quad-Ring
- 1pcs 90025K388 AS568A - 227 Quad-Ring
- 1pcs 90025K464 AS568A - 229 Quad-Ring
Last edit: 16 years 7 months ago by BigJohnT.
13 years 1 month ago #39108
by gmouer
Replied by gmouer on topic Rebuilding a CHNC I Collet Closer
the pictures have disappeared from this thread. Any chance there is a copy of them around anywhere? Planning a mod to this collet closer and some pics would sure help.
13 years 1 month ago #39132
by BigJohnT
Replied by BigJohnT on topic Rebuilding a CHNC I Collet Closer
I wonder what happened to the photos... the edits look strange to me all withing a few minutes and not done by me.
I can't find the photos...
JT
JT
13 years 1 month ago #39135
by gmouer
Oh well, it was worth a shot to ask, just in case you had copys of the pics floating around. Thanks for looking into it.
Did you ever get the air leakage rate under control?
13 years 1 month ago #39136
by BigJohnT
On a long shot I looked at my old photobucket account and found the photos.
s47.photobucket.com/user/johnplctech/lib...Closer?sort=3&page=1
The collet closer leaks air when open and I just unplug the hose if it will be open long. The CHNC uses a lot of air...
JT
JT
- PsychoTech
5 years 6 months ago #205273
by PsychoTech
Replied by PsychoTech on topic Re:Rebuilding a CHNC I Collet Closer
Hi there Big John T, I am having the same issue with my CHNC 1, and am curious if you may have gotten the dash numbers reversed in the first two o-rings you posted. When I search McMaster for 1879T23, I pull it up with a dash of 016 and when I look up the 9452k18, I get a dash of 010.
Do you still have these rings sitting around? I realize I'm responding to an 11 year old thread and am guessing you've tossed them or given them away by now, lol.
Time to create page: 0.419 seconds
