Linuxcnc for CNC-STEP HIGH Z 400
7 years 5 months ago #135055 by Frustrated Toolpaths
Thank you pl7i92.
I had hoped utilisateurflo got theirs running as it's much closer to the machine I will have.
I'll try to post a version that works once I get mine up and running.
7 years 1 month ago - 7 years 1 month ago #145858 by windrad
I had the same problem with getting the Zero 3 control working with LinuxCNC. In my case it looks like a problem of the stepconf wizard. The estop and the charg pump for some reason conflict.
In my case it helped to comment out the following:
net estop-out charge-pump.enable iocontrol.0.user-enable-out
and add:
net charge-pump <= charge-pump.out
net estop-ext => charge-pump.enable
in the highz_s400t.hal (see attachment) file after finishing the stepconf wizard. Attention this change is overwritten each time you run the stepconf wizard.
I also attached my latest version of the configurarion. You can use it as a starting point and adapt it to your needs.
File Name: 2019_09_22...Z400.zip
File Size:4 KB
Last edit: 7 years 1 month ago by windrad.
The following user(s) said Thank You: Frustrated Toolpaths, pagan_dan
7 years 4 weeks ago #147013 by Frustrated Toolpaths
Thank you,
I ended up with a different machine in the end, a cnc router parts/avid cnc machine.
This produced even more headaches for a linuxcnc controller....got there in the end, it's mostly running as intended, just need to get my estop to talk to linuxcnc via the g540, which shouldn't take too long with a bit of searching :)
7 years 4 weeks ago #147016 by pl7i92
changing a HIHG end CC to a low cost is not that good behavior if you got the money for it
why did you go for this mashine
there are so many others to be considert on a KIT
like sorotec or dold ....
7 years 4 weeks ago #147024 by Frustrated Toolpaths
After a lot.......LOT.....of looking and searching various machines for my purpose I decided on the avid machine (with some serious reservations and worries) I have been pleasantly surprised so far by the machine (mine is far from the standard build) and isn't cutting quite yet as I still need to fit the spindle and hook up the vfd through g540 and LinuxCNC.
I had some unusual requirements that took me away from the manufacturer's you mentioned.
3 years 7 months ago #267347 by pagan_dan
Thanks for the configurations, I have used them to 'almost' get my old s400 working. I am new to LinuxCNC and having trouble translating these older configuration files to the newer format though.
I must be missing something or doing something wrong, as although everything works I'm not get the correct scale for each axis. The manual shows "Steps per Revolution 1/10 Micro-Step : 2000". How does this translate into Motor steps per revolution and driver micro stepping? I have tried many different values but some don't sound good and i don't want to damage anything. The default settings of 200 / 2 'work' but they give a scale of around 66. But these configurations files show scales of 200 / 200 / 333.33333.
From looking at the manuals I just spotted the thread pitch is 6mm for each axis, so I have changed that from the default 5mm. Do i also need to change the motor leadscrew pitch settings?
I have tried editing the .ini file to the scales in the conf files posted here manually after running the stepconf tool, and that got the scale much closer, but still not quite right. Any advice on what I might be missing or things I could try would be much appreciated. I'd rather get this right in the stepconf tool, so I don't need to manually alter settings if possible.
I can upload by configuration files here if that helps.
Time to create page: 0.121 seconds
