- Thank you received: 63
LinuxCNC S-Curve Accelerations
6 years 2 months ago #177708
by grijalvap
Replied by grijalvap on topic LinuxCNC S-Curve Accelerations
github.com/synthetos/TinyG/wiki/Jerk-Con...led-Motion-Explained
I'm curios about this project they have jerk controlled motion.
can we learn about it and implement in Linuxcnc?
6 years 2 weeks ago #186389
by arvidb
Replied by arvidb on topic LinuxCNC S-Curve Accelerations
Speaking of "cases and corners" in a jerk-limited jog planner, here's an interesting one:
t = 0.0 s: User presses right -> machine accelerates axis in positive direction (v_max reached at t = 0.30 s).
t = 0.35 s (first vertical line): User presses left instead -> machine accelerates axis in other direction to bring vel towards negative.
t = 0.58 s (second vertical line): User releases button -> machine stops axis.
At t = 0.58 s, vel is still > 0, but acc is maximally negative. There's not enough time to jerk acc to zero before vel has swung negative. So to stop the axis without violating the jerk limit, its velocity must swing negative before returning to zero; although the button was released while velocity was positive, you can see the position actually retarding a bit before the axis stops:
Fun stuff! O__o
Fun stuff! O__o
The following user(s) said Thank You: Shu
6 years 2 weeks ago #186463
by arvidb
I used a recursive algorithm and data structure to generate the plot above:
The "level" in the node diagram then corresponds to a certain polynomial degree: s3 is linear with respect to position, s1 & s5 are quadratic, and s0, s2, s4 & s6 are cubic in the example above.
The number of segments grows as a power of 2: 2^N-1 where N is the degree of the polynomial. So acceleration-limited motion is 2^2-1 = 3 segments, jerk-limited is 2^3-1 = 7 segments, snap -limited is 2^4-1 = 15 segments, and so on.
Just for kicks, here's a pop-limited (6th-degree, 63-segment) move generated by the exact same code, just fed with a longer limit vector (jerk = 5 m/s³, snap = 100 m/s⁴, crackle = 4000 m/s⁵, pop = 320000 m/s⁶):
Now this only works because the move starts with no initial motion, and the length of the move is carefully selected, as is the ratio between the limits, so don't get your hopes up too high for a generic pop-limited jog planner!
Now that I think about it though, auto-selection of any limits above acceleration (like jerk) might not be a bad idea? Not many users will want to dig into the maths and physics to learn how to choose sane limits... They/we just want nice motion, right?
6 years 2 weeks ago #186465
RIGHT!
Replied by Aciera on topic LinuxCNC S-Curve Accelerations
RIGHT!
6 years 2 weeks ago #186466
by arvidb
LOL :lol:Aciera wrote: RIGHT!
- Thank you received: 1480
6 years 1 week ago #186725
Replied by Todd Zuercher on topic LinuxCNC S-Curve Accelerations
So how many chickens do we have to sacrifice to get it?
Time to create page: 0.083 seconds
