Linuxcnc on Debian Stretch 9 32 bit preempt rt
7 years 6 months ago - 7 years 6 months ago #131280 by Clive S
No eBay APP ID and/or Cert ID defined in Kunena configuration
tommylight wrote:
Clive s wrote: If you are using screwed rod as a lead screw say 10mm it could be 1.25mm pitch (ie one rev would be 1.25mm travel)
10mm or M10 would be 1.5mm
M8 is 1.25mm
I agree but you can also get 10mm rod with 1.25mm pitch. steel and brass B)
Last edit: 7 years 6 months ago by Clive S.
  • AnnoyingMutt
  • New Member
  • New Member
7 years 6 months ago #131290 by AnnoyingMutt
Replied by AnnoyingMutt on topic Linuxcnc on Debian Stretch 9 32 bit preempt rt
Or you could cut just about any pitch thread you want with a lathe ;)
Metric Fine Thread
www.newmantools.com/tech/threadmf.htm
Metric Coarse Thread
www.newmantools.com/tech/threadm.htm
Just to be a smarty pants :P
7 years 6 months ago #131293 by Clive S
AnnoyingMutt wrote: Or you could cut just about any pitch thread you want with a lathe ;)
Metric Fine Thread
Yes but that is not what the op wanted to do. He was asking what numbers to put in stepconf
  • AnnoyingMutt
  • New Member
  • New Member
7 years 6 months ago #131297 by AnnoyingMutt
Sorry I was unaware I wasn't allowed to make mention of screw pitches.
7 years 6 months ago #131299 by Clive S
AnnoyingMutt wrote: Sorry I was unaware I wasn't allowed to make mention of screw pitches.
Sorry if I offended you. Of course you can mention screw pitches. But is it relevant to the op's question in my opinion it just muddies the water for a new op.
  • AnnoyingMutt
  • New Member
  • New Member
7 years 6 months ago #131332 by AnnoyingMutt
[response_to_hypocrisy]
I wasn't offended, just a little confused re the hypocrisy of your post. Actually you seem to have an over inflated ego if you think anything you post could make me choose to be offended.
Linking to an ebay listing is relevant because it backs up your post ?
[/response_to_hypocrisy]
[sensible]
I linked those charts to show that there are more than one pitch is related to a particular diameter. Yes some diameter/pitch combinations are more common than others.
[/sensible]
[smart_arse]
But then again M25x1.0 is quite common
[/smart_arse
[sensible]
Just the clear things up, the pitch is the distance from one peak to another peak (or trough to trough) which is equal to the amount a nut will move when rotated one full turn.....that is for single start threads which are the most common dealt with. Which more or less backs up what has previously been stated.
[/sensible]
Time to create page: 0.058 seconds
