Gmocappy fires relay twice
7 years 1 month ago #144493 by dgarrett
Replied by dgarrett on topic Gmocappy fires relay twice
The userspace pin halui.machine.is-on is following
realtime motion pin motion.motion-enabled.
Some investigation shows this behavior with gmoccapy
has existed for a while -- it has probably just
never been reported.
The problematic code is likely in this function or
its triggers (2.8 branch):
github.com/LinuxCNC/linuxcnc/blob/fbd3f7...py/gmoccapy.py#L2296
Using configs/sim/gmoccapy/gmoccapy.ini, Pressing the Machine-On button:
Suggestion: file a bug report (issue) on github and/or notify Norbert
7 years 1 month ago #144501 by bevins
Replied by bevins on topic Gmocappy fires relay twice
PCW wrote: Does your axis config use halui the same way?
What pokes halui.machine.on and halui.machine.off ?
Yes it does. This basically a generic pncconf. I am just starting towork on the configs and I wanted the customer to use gmocappy.
I am really comfortable with Axis, so I am testing in axis and thenmodifying gmocappy config. I have two machine configs.
7 years 1 month ago - 7 years 1 month ago #144502 by bevins
dgarrett wrote: The userspace pin halui.machine.is-on is following
What is triggering motion.motion-enable?
/EDIT nevermind I think I understand how it works. The function (on_tbtn_on_toggled) looks like it works. Must be in the triggers in the widgets.
Where can I create a bug report?
Last edit: 7 years 1 month ago by bevins.
7 years 1 month ago #144505 by cmorley
7 years 1 month ago #144706 by newbynobi
Hallo @ALL,
i am able to reproduce the behavior. so now is just to find the reason and bug fix that one.
I apologize for the inconvenience.
Norbert
The following user(s) said Thank You: bevins, tommylight
6 years 9 months ago #154343 by bevins
Any headway on this issue?
Time to create page: 0.129 seconds
