Slow work of rotary axis
6 years 5 months ago #169570 by aleksamc
Replied by aleksamc on topic Slow work of rotary axis
I also tried to configure python module from Remap extending G-codeRemap docs
When I run linuxcnc from terminal I get errors
Found file(REL): ./ax4laser.hal Found file(REL): ./custom.hal cant resolve path to 'home/user/linuxcnc/configs/ax4laser/python/toplevel.py' Interp ctor: cant instantiate Python plugin cant resolve path to 'home/user/linuxcnc/configs/ax4laser/python/toplevel.py' Python plugin configure() failed, status = -5 cant resolve path to 'home/user/linuxcnc/configs/ax4laser/python/toplevel.py' Python plugin configure() failed, status = -5 RTAPI: ERROR: Unexpected realtime delay on task 1 This Message will only display once per session. Run the Latency Test and resolve before continuing.
6 years 5 months ago #169701 by aleksamc
Today I made connection of python module, as wrote in Having another go at remaping M6
When I run linuxcnc no error are present.
But I still cannot run filter.py. Permission denied and nothing more.
6 years 5 months ago #169714 by tommylight
Replied by tommylight on topic Slow work of rotary axis
From the beginning:
What Linux are you using?
Since you are getting way to many permission denied, it is much easier and faster to reinstall linux and start over.
Somewhere somehow you used sudo where it was not supposed to be used, so now it is tedious to try to figure that out.
6 years 5 months ago #169771 by aleksamc
I use linux 2.7.15
Do you think, I need to reinstall it?
My be some python was not installed or enviromnment is wrong.
When I write in python program
#! /usr/bin/env python
I get such file not found or something similar.
Time to create page: 0.203 seconds
