Slow work of rotary axis
6 years 7 months ago #162159 by tommylight
Replied by tommylight on topic Slow work of rotary axis
Do a google search on how to fix file permissions in linux, but do be careful, there are a lot of things that can be messed up with that.
6 years 5 months ago - 6 years 5 months ago #169392 by aleksamc
Replied by aleksamc on topic Slow work of rotary axis
get error 127 "file not found".
I tried 777, 755 and 666.
I don't understand why I get that filter.py file not found. It's present and pass is written to configs folder.
File has complite permissions now -rwxrwxrwx
Last edit: 6 years 5 months ago by aleksamc.
6 years 5 months ago #169410 by MaHa
Replied by MaHa on topic Slow work of rotary axis
I get exactly this error, when the path to the filter is not correct, example '/home/NcFiles/Filter/filter.py'
6 years 5 months ago #169544 by aleksamc
I checked my problem more presicely.
If permissions has number 7 (mean x-execute), then I get error 127 "file not found".
If I set permissions with number 6, then I get error 126 "permisions denied".
Possibly, problem is in something else.
in the directory usr/bin/.. I don't have file python, but files python2.6 and python2.8
Or could be problem that linuxcnc doesn't have permissions?
I had problem with reading python files by linuxcnc in the past. I didn't solved that problem.
6 years 5 months ago #169547 by tommylight
Did you check permissions for the folder where the file is located ?
6 years 5 months ago #169553 by aleksamc
I checked, folders has permissions read & write.
I also replace file.py to user/ and also tried. I got the same result, not matter what folder is.
Time to create page: 0.272 seconds
