- Thank you received: 5334
Making 0-10V output work with spindle in HAL
6 years 6 days ago #187354
Pretty sure the PWM pin is brought out so that it can be used as a standard 5V output if the spindle analog out is not used
Replied by PCW on topic Making 0-10V output work with spindle in HAL
sushantkurren wrote: I'm aware that's the case, but I do not know where to then wire the PWM from the breakout board into - there's documentation for everything except that
6 years 6 days ago #187395
Replied by Aciera on topic Making 0-10V output work with spindle in HAL
As PCW suggested. You would leave the green PWM terminal unconnected as this is the 5V Signal coming from the Parallel port.
- Thank you received: 1480
6 years 5 days ago - 6 years 5 days ago #187416
Replied by Todd Zuercher on topic Making 0-10V output work with spindle in HAL
With that breakout board (below) uses the 12-24v combined with the PWM signal on pin 1 (the computer side) to output the 0-10v signal. Don't connect anything to the pin1 output on the breakout board. He was trying to say that in your hal file the PWM output gets connected to the parallel ports pin 1 there. Then the breakout board uses that signal to generate the 0-10v signal. (The pin 1 output on the breakout board is for situations where you are not using the 0-10v signal and want to bring out the output from parallel port pin 1 for other uses.)
Last edit: 6 years 5 days ago by Todd Zuercher. Reason: add image
5 years 11 months ago #190426
by AlexDoran
Replied by AlexDoran on topic Making 0-10V output work with spindle in HAL
Hi there, I am attempting the same thing. Any news on if you got it to work?
I have it wired correctly, the relay engages, I'm just not sure if the HAL settings posted here worked for you?
I'm a total LinuxCNC beginner.
5 years 11 months ago #190698
I can't say if the original poster was successful. But I am successfully using one of the above BOBs to control the VFD(s) on a router. And it was long enough ago that I don't know/remember what if any issues may have been present in his last hal configuration file he posted. However I am hesitant to post my own config files as an example because they are far from a standard router config. I'd suggest starting your own thread, asking specific questions and posting copies of your own configuration files to get the help you need.
2 years 11 months ago #285150
by Gurt
Replied by Gurt on topic Making 0-10V output work with spindle in HAL
Hello guys,
I face the same problem with the same 5 axis breakout board. I am also a Linuxcnc beginner...
I am able to start and stop the spindle via Linuxcnc, using the relay on the BOB, which is connected to the FWD of the VDF.
A 12V power supply is connected to the BOB, so the board is able to generate the 0-10V for the spindle speed.
in my HAL file, I use the pin1 for the pwm but I am only able to change speed directly on the VDF, not via linuxcnc.
If I measure the 0-10V output, it is stuck at 9.5V. The speed displayed in Linux cnc doesn't change when I click on "+"
If you can check my HAL, there is maybe something wrong...
If someone could help me, it would be great. Thanks a lot
Time to create page: 0.062 seconds
